My first Tesla supercharger experience.
evowner
Frank
SW Ohio
Retired EE
I would like to share some observations on a recent trip on Sat 02/01 in our 2024 E150 Lightning Lariot from Cincinnati, OH to Louisville, KY for a show at the beautiful Kentucky Arts Center. The mileage was approximately 260 round trip, which included several stops on the way to the venue.
We started off with an almost full battery, about 300 miles. We took I71 South, which heads mostly southwest, so I assume there was a head wind all the way, although I don’t know for sure or how strong it was. It is hard to tell when using Blue Cruise, which we used for the whole trip. It worked well for us. It is like having a chauffeur.
The trip down was mostly expressway, and then a few stops around Louisville. We had no heat or any other battery consuming accessories, except the radio (Sirius) and Blue Cruise. It was in the upper 40s and sunny so we were plenty comfortable. I drove at 65 mph 80% of the way. I upped it to 70 mph to see if I could tell if there was a significate reduction in mileage. I could not tell. The actual mileage for the trip down was 135; we used about 170 miles of the range of the truck. This is a much greater loss than we would have experienced with our other EVs.
After we got done at our second stop in Louisville at about 5pm I started thinking about the trip back. It appeared that we had enough range (130 miles) to make it if there were no unforeseen circumstances and we did not use any other battery draining accessories. I usually don’t like public chargers, mostly because it is more expensive than at home, however the risk of running out of electric or having to charge on the way home after midnight did not sound like fun. We had plenty of spare time for this trip and decided to try our first Tesla supercharger event.
I use Android Auto and turned on the filter in Google Maps for EV charging locations. The default filter listed stations with compatible connectors. I toggled that off and then it listed mostly the Tesla charging stations. I looked for the closest supercharger station, and it turned out that it was less than 2 miles away, and is next to a Meijer so there would be bathrooms as well as something to do. I then looked on the Tesla app to verify the location and check the current conditions. I saw that there were 12 chargers, 1a was not working, and 6 were in use. I was a little concerned that I may not be able to get in because more than likely the current users are taking every other slot.
When we arrived there were no open slots that we could use because of the need to have 2 open slots to charge the truck. It turns out that 1a, which was not working, is set up for vehicles that have the charge plug in the same location as the Lightning. After about 5 minutes and someone with a Tesla returned unplugged and left. We pulled into the slot and the front of the truck fit nicely between the chargers. I selected the charger in the Tesla app, and then I pulled out my adapter, which I purchased on amazon, and plugged it in. The first try did not work. If I had taken the time to read the instructions it would have worked fine. My process is that I connect the adapter to the Tesla charge cable and lock it in place, then plug the adapter into the truck. I pressed start charging in the Tesla app and it worked and charged the battery up to 90%, which is the setting I had for my Tesla model S, I guess I can change that to 100%. It took about 35 minutes to take it to 90% and cost $20. None of the Tesla owners came over objecting to us using 2 spaces, although I can imagine that might change if there were no other chargers open.
By doing it this way we really reduced any stress we would have had worrying about running out of electric. We were able to have heat, butt warmers and steering wheel heat all the way home. None of which we would have been able to use if we had not recharged. $20 well spent.
My first experience with the Tesla superchargers was excellent. This trip also just expanded the range that I would ever take this vehicle. We could have gone all the way to Nashville, then recharge there for the trip home. Prior to this we probably would have taken the Hybrid or another ICE vehicle.
I look forward to many more trips without the worry about range.
It turns out that all of the members on here were right about the public chargers being easy and not inconvenient.
Finally, thanks to all of those that shared their experiences with the Tesla superchargers which made ours much easier.
MFT
2023 Lightning
Used my first Tesla Charger yesterday in San Antonio @ .30 per kWh. Super easy and convenient. I'm guessing it was a good rate since it was so early in the morning and this Tesla charging station was built correctly so I did not have to occupy 2 spaces.
Ford F-150 Lightning My first Tesla supercharger experience. PXL_20250202_121047667.MP
Ford F-150 Lightning My first Tesla supercharger experience. Screenshot (15)
Chillguy
Marek
DFW
2023 Ford F-150 LIGHTNING Platinum
Allstate Agency owner
I came to understanding that I should use only Tesla Superchargers on my trips. Especially here in TX many are located within Buc-ee's so it's so so convenient!... These SC stations rarely have less than 20 plugs so it's never been a problem... We usually are charged up to 90% even before we're done at Buc-ee's so it's super nice!.. Thank you Elon! (Not that I'm not paying for it, but still.. I experienced other charging stations where they're not working or half of them are 50 kwh!... Which is a colossal waste of time!)
A couple of points.
First, you don't compare the usage of battery vs. what the GOM says to calculate loss. Pointed out many times here. The GOM at 100% often displays the default of 320 miles, which isn't going to happen in winter.
Second, the charging level at a Tesla Supercharger has nothing to do with the Tesla app, and everything to do with the preset 90% limit in the truck, that you can simply change anytime you want to charge to a level you want. But please don't charge to 100% unless you need the range, others are waiting to charge as you noted.
MFT
2023 Lightning
The Buc-ee's on the way to San Antonio not only had Tesla Chargers but also had a row of charges in the back of the property that were vacant and super fast. Very convenient
Ford F-150 Lightning My first Tesla supercharger experience. PXL_20250202_022716970.MP
evowner
Frank
SW Ohio
Retired EE
I realize that now. When I first got the truck I tried to set the charge level to 90%. The only setting I could find was a 'one time charge level setting' I took that to mean 'one time' charge level setting. I set it to 90%. Now when I look in the fordpass app it is still set to 90%. I think the app may have changed. Clearly I still have a lot to learn.
evowner
Frank
SW Ohio
Retired EE
Thanks, Not sure what I did wrong, I know it is not very scientific, but that is the way I have done it for over 8 years now, and it has worked well for me.
I realize that now. I tried when I first got the truck I tried to set the charge level to 90%. The only setting I could find was a 'one time charge level setting' I set it to 90%. Now when I look in the fordpass app it is still set to 90%. Clearly I still have a lot to learn.
Pull up to charger. Set onetime limit to X%. That session charges to that percentage.
Thanks, Not sure what I did wrong, but that is the way I have done it for over 8 years now and it has worked well for me.
Drive vehicle in summer. Note miles per kWh. Drive vehicle in winter on same route, note miles per kWh. 1 minus winter over summer is loss.
evowner
Frank
SW Ohio
Retired EE
WOW Mercedes chargers, haven't seen those yet. That must be some PREMIUM juice. :)
Reactions: MFT
evowner
Frank
SW Ohio
Retired EE
That setting seems to be the new default now. Every time I charge now it goes to 90%.
Ok thanks. I will try to remember that
90 is the default. Change it to 80%. Or 95%.
evowner
Frank
SW Ohio
Retired EE
It's a bit confusing to me. the first time I charged it with a L2 charger, after bringing it back from the dealer, it charged to 100%. I looked for the setting in the app to limit the charge and found only the onetime charge setting and changed it from 100% to 90%. I don't know. I will figure it out over time. Thanks for your help.
Firn
23 Pro ER
Not sure if it came across but what Rick is saying is that the range display on the dash is a lying sob...no seriously, it is.
Ford fakes the range number as the charge gets close to 100% and it isn't accurate. Well, it isn't accurate at all anyways, but it's even worse at 100%.
Also, the 90%/100% thing is different at L2 chargers vs Fast chargers. What was said was for fast chargers, it's a bit different for l2 chargers.
Pod
2023 AMB Lightning XLT SR
Those Mercedes Benz chargers are PREMO!!! They use ChargePoint to connect. If you see them, use them. Well designed and solid as a rock.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
They are Alpitronic chargers. The new Ionna stations are using them too and they are solid. I shared one with a Hummer and he was getting over 200 kW and I was getting about 115 kW.
