Repair/replace broken mirror trim
WalleyeGuy
2024 Flash
Well, just over a month in and I have a broken mirror. Power folding mirrors were the biggest thing I was missing from the Flash model, and it bit me early. Clipped part of my garage and broke the trim on the mirror. I can't see to find a replacement for just the outer trim. Is there a way to replace that without having to replace the whole mirror? Or should I try searching junk yards?
There is also a small crack in the blinker light
Ford F-150 Lightning Repair/replace broken mirror trim 20241211_100638
21st Century Truck
Martin
I suggest scouring EBay or a breaker yard (plenty of those) for a F150 mirror black plastic casing and just replacing Your mirror's guts into the casing. It's not that hard with patience once You pull the mirror glass off.
I am with You on the lack of power autofold motors in the lower Lightning mirror trims. I'm saving pennies to get these power mirrors on my 2023 XLT. It's the one option my XLT ER 312A doesn't have that I wish it would.
msdickerson
North Central Massachusetts
I cannot say about the housing cover, but the blinker light on Amazon costs about 25$.
samster
Samarth
Ford F-150 Lightning Flash 2024
Did you end up finding the pieces you needed? The same exact thing just happened to me… I actually have a slight crack on the front part of the casing as well I’m not sure if they make replacement parts for that side?
Ford F-150 Lightning Repair/replace broken mirror trim IMG_3836
Ford F-150 Lightning Repair/replace broken mirror trim IMG_3833
msdickerson
The blinker light can be had on amazon for about 26$. The frame I have not looked for but I would look on amazon as its pretty standard replacement item and ford will charge probably double than an aftermarket one.
Vakatack
Eric
New Jersey
2023 F-150 Lightning - Platinum
Anyone know if it's easy to just replace the trim? It looks like it goes deeper behind the glass. I was able to find a picture of the mirror with the glass taken out but I haven't found anyone who actually takes the plastic apart.
Ford F-150 Lightning Repair/replace broken mirror trim 1740510716916-fa
Ford F-150 Lightning Repair/replace broken mirror trim Screenshot 2025-02-25 at 2.13.53 PM
