Rotary Shifter Part Numbers
Space Flash
Richard
2025 F-150 Lightning Flash
Installed the injection molded rotary shifter adapter and the rotary shifter from ManionMakes in our '25 Flash a couple of weeks ago. Works like a champ and looks totally OE. Only another Lightning owner would know that it didn't come from the factory like that.
The shifter is motorized and illuminated. If I shut the truck off without taking it out of gear it automatically puts it in park. The drive and neutral hold letters light up and the dial has a nice blue ring when the headlights are on.
Installation went without a hitch. The adapter's fit and finish are perfect.
The shifter I received was brand new. PN: LX6Z-7P155-U
Highly recommended!
Ford F-150 Lightning Rotary Shifter Part Numbers Lightning ManionMakes Rotary Shifter
Robocop
holy crap! this is quite an update.
so the injection moulded part doesn't require any finishing at all? so plug and play? that looks amazing.
Dahveed
Salina, Kansas
2025 Ford F-150 Lightning Flash (Job 2)
Yup. It looks absolutely OEM. Only thing missing is a little rubber pad for the bottom of the storage compartment. The one from the original shifter is contoured and doesn’t lay flat.
mt2525
Michael
2022 F150 Lightning XLT 2024 Cadillac Lyriq
Just received this part #JX6P-7P155-FG mounted in the conversion piece from Etsy. Before I attempt upgrade has anyone used this particular part number?
Mike G
N. AL, USA
Has Ford assigned the ManionMakes injection molded version a part number yet? :)
I'm still rockin' my original 3D printed version, but the new one looks very nice! I might have to upgrade.
Fifty50Chance
Chance
2020 Honda Fit
Edit: I'm an idiot! When you plugin the shifter you need to pull the gray piece back to lock it in. I'm leaving this just in case someone else makes the same mistake. It is working fine and looks great
I swapped and got an error. So swapped back and now I'm getting an error any my truck is stuck in the driveway!"
In November I purchased a JX6P-7P155-U (Ebay) and finally decided to install it today. Install on an XLT was more of a pain than expected but I was able to figure it out. When I started it up I got the error above. The shifter did nothing.
So I swapped the original back in. It is in the stow position and same error. Shifter is stuck down.I can't move the vehicle.
I looked at the shifter and it looks like I received the wrong part JX6P-7P155-FE. This is my fault for not looking at it when I got it but I'm annoyed I looked at the listing and I have the right one.
If anyone has any ideas how to just get my truck moveable again!
Fixed see edit at top
Space Flash
Richard
We’ve all been there, done that at some point. 😉 Glad you got it sorted! 👍
Keep the shiny side up! 🏎
kubel
US
2024 Ford F-150 Lightning Flash (+9.6kW PPO, Max Tow)
LX6P-7P155-EH from ebay might ship out a non-motorized version that doesn't feel very good.
Edit: Looks like ebay seller "manufacture-factory" shipped the wrong part, MZ9P-7P155-AA, which is a free spinning (non-gated) non-motorized version, and is now claiming they are all the same part. Buyer beware. It works. And it's probably going to be more reliable. So I don't know if I should just keep it...
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_20260727_180259
Finished product:
Ford F-150 Lightning Rotary Shifter Part Numbers finishedproduct
My final thoughts: I'm agnostic.
Pros:
Looks stock
Gets rid of a failure prone part
Allows for work surface to be lowered while in gear
Easy mod to do
Cons:
$100 for a piece of plastic is pricey
It's becoming more difficult and expensive to source rotary shifters
I find myself selecting the wrong gear a lot
My biggest concern was that I would miss the shifter as a place to rest my hand, but that turns out not to be the case. I just put my elbow back a little more and my fingers rest just ahead of the arm rest.
