Tire Sizing for a Lariat
xwing
Jeff
Okeana, OH
2023 F-150 Lightning
I have a 23 Lariat and am thinking about putting some Michelin LTX AT/2 tires on that I have taken off of my F-250. They are 275/65R20. According to the tire sizer they are about an inch taller. I know I'm going to loose some range, but it beats buying a set of tires. My question is does anyone have experience with one inch taller tires on a stock truck? My concerns are rubbing on turns in front.
Ford F-150 Lightning Tire Sizing for a Lariat TireCompar
it's probably more about the weight in the bed lowering the shocks which could then cause the tire to rub at the top ... but unless you're towing 10,000lbs, it's still probably no issue... you can always try it and see - you already own them!
Robocop
2022 Platinum; 1962 Lincoln Continental
The diameter variance exceeds 3% which is not recommended.
