Trip meter failing to factor in regen energy
Only a small number of folks are driving up and down mountainsides.
Once you've gotten onto normal terrain, mild hills & dales or flat grounds, how long before the "This Trip" normalizes?
johnr
Exeter, CA
2023 Ford F-150 Lightning Lariat, Tesla Model S
Design and sell EV charging adapters
I live near the base of a mountain, so I suppose my experience will be a bit different from most. So far, going down the mountain I've always ended up with more energy than when I started, so the meter has always showed 0% used for driving. I'll have to try this later on a longer trip, extending the flat land portion at the end to use up all the energy gained, and see how the meter reads then. I suspect it will probably normalize once the net energy usage becomes positive. It'll be a few days before I have time to try this.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
Ford Pass use to have a Driving Logs tab that would tell you how many miles during your trip, mi/kwh, and how many miles you gained from Regenerative Braking. They pulled it a few months ago because the data was buggy, but when it worked it was nice to look at. Hopefully they bring back a cleaner version in the future.
