XLT OEM Bed Lights Install
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
For my 2024 XLT, when I went to order the parts from Ford, per the p/n's from way back at post #11
The lamp switch came up as replaced by p/n SW7733
FYI for anyone following along this old, but interesting thread.
rio
CT
2016 Chevy Volt, 2023 F150 Lightning Pro
Finally got around to doing mine with success! My '23 Pro does not have Tow Tech Package and therefore I had to run the 2 extra wires from the BCM plug to the bed light plug. Thank you @BhamDCam for outlining this process (both the post and video were super clear).
Ford F-150 Lightning XLT OEM Bed Lights Install bed lights
Robert
NW Ontario Canada
Contractor
Since the 2024 XLT has the two extra wires, but not the 'dummy plugs' it would be nice to get the correct OEM wire harness that Does have the two plugs for the bed Lights.
Since there are sooooo many wire harness options, I read 15 pages of this thread and another 15 pages on the Gen14 forum, then started with what I have on the truck:
RL3T-13A409 -ZAC My truck has the bed scale, BLIS, trailer plug and 120v bed plugs.
I assume our tails are LED's (there is a lot of chat about black vs grey tail light plugs on Gen14)
Looking for the correct harness to support what I have + the bed lights and switch I found:
RL3Z-13A409-E
which lists tail lamps level 2,Lighting package level A, power inverter #1, Dearborn Electrical Vehicle Centre. {doesn't note onboard scale?}
RL3Z-13A409-P
which lists Dearborn Plant onboard scale, inverter (2,3,4,5) - {no idea which inverter I have on 2024 XLT Lightning}
Gen14 comments include the 13409-E Without Bed Scale. {Also Suffix G, J, K}
The Suffix N seems to be "with bed scale' but for F-150 ICE built in Kansas City.
The 13A409-P seems to be the correct harness, but not sure how to confirm it. Showing out of stock at the moment too. What can I check on the truck?
e8stormbreak
Erik
2024 Ford Lightning XLT
Has anyone been able to do this on the 2024s? I didn't have the dummy plugs, so I wired into the BCM, and I think that it's pins 10 (power) and 11 (com) vs 8/9 for the 2023s and below.
However, I went to enable in FORScan and I'm missing a few of the menu options that you all have had, I can only find one reference to the cargo lights in the BCM screen, and in the as built, I'm not seeing any other references to bed lights. Any tips on FORScan changes for the 24s would be amazing!
Markip
Barrie Ontario
2025 F150 Lightning xlt
Manager of Operations
Hey guys connector c408 does any one know what pins it uses I'd like to make my own harness to run bed lights without splicing cables in the harness
This is how to do it on a 2023 Pro (or XLT I believe - parts are in the video description below and available from Amazon):
See Install video: 22-23 F150 Lightning Bed Light Install XLTPro on
YouTube at:
"This video is for xlt and pro owners. Upper trim trucks should have these already. However only pros equipped with zone lightning can do this (and all xlts). Pros without zone lighting will not be able to turn on the lights through forscan.
Ford Part# used:
Wire assembly 1 ML3Z-14A411-F
Wire assembly 2. ML3Z-14A411-D
Lamp switch. FL3Z-9C888-B
Aftermarket Bed lights (includes 2) https://amzn.to/41keEYF
Or you can use oem bed light (includes 1, must buy 2) "
Note Amazon sells these as well:
Aftermarket Switch: https://www.amazon.com/Switch-Ford-...65-9b9e-58c7dbd5e69c&pd_rd_i=B0BTY3Y4M8&psc=1
Aftermarket wire assemblies (both): https://www.amazon.com/Illumination...65-9b9e-58c7dbd5e69c&pd_rd_i=B0FCXDRSFS&psc=1
The 3 FORscan tweaks to enable bed lamps on Pro are in the video at minutes 2:57+
In BCM (body control module) find and change:
Bed Lamp - set to enabled
Rear Exterior Courtesy Lamp Switch Input - set to Manual Puddle
Rear Exterior Courtesy Lamp Type - set to Bed Lamp
Robert
NW Ontario Canada
Contractor
I bought the lights, switch and two light harnesses for my 2024 XLT but the existing wire harnesses under the truck do not have the place to plug the light-harness in (no dummy plugs). Need to figure out which base truck harness I need now. The truck has the 360 lights and bed scale options, not sure which harness is correct for this now...anyone know?
I saw a video where some one had that same problem and bought an after market kit from vendor that had the wiring needed...I'll see if I saved the link...see this video - it was a Starkey products kit:
Video:
Kit:
https://www.starkey-products.com/pr...ing-kit-2021-2023?_pos=1&_sid=88e543e78&_ss=r
PA Lightning
Tbone
PA
2025 Flash, 2022 Lightning Pro(traded)
I am not as mechanically inclined as some of you fellows so I went to HF and got two puck lights to attach to the bed with velcro.
Ford F-150 Lightning XLT OEM Bed Lights Install 1784290041018-rc
I installed the bed lights and switch, and did the FORscan tweak, works like a charm.
Very easy on my 2023 Pro, I think the XLT is also the same.
