Deleted member 20876
Guest
Finally pulled the trigger! I just had the Eibach Pro Kit installed on my 2024 Antimatter Blue Metallic Ford Lightning. I kept the stock struts, because I was not so much looking at performance as much as I was comfort. I am really happy with the results. The ride is great! The camber kit is on order and will be installed in two weeks.
Ford F-150 Lightning Eibach Pro-Kit installed on 2024 Lightning Flash IMG_3779
Ford F-150 Lightning Eibach Pro-Kit installed on 2024 Lightning Flash IMG_3781
Ford F-150 Lightning Eibach Pro-Kit installed on 2024 Lightning Flash IMG_3780
Ford F-150 Lightning Eibach Pro-Kit installed on 2024 Lightning Flash IMG_3782
RSMLightning25
Richard
Schertz, TX
2011 FX2 F-150 5.0 Blue Flame, 2025 Lariat Lightning Anti-Matter Blue
Network Security
Looks great! Is the truck still floaty or did that go away with the kit? You just did springs, correct? How low did you go in the rear?
Guest
Still a little floaty just not as bad, however I asked for stock ride. Yes, just the springs. The kit lowers the rear 3".
RSMLightning25
Richard
Schertz, TX
Network Security
Thanks for the update. Really looks good with the rear being a lot lower. Any other plans other than the camber kit?
Guest
Thank you! The only plans I have is wheels, bed cover and power running boards.
RSMLightning25
Richard
Schertz, TX
Network Security
Very nice. I'll keep the stock wheels and I moved the bed cover over from my 18 5.0. I have some tremor running boards I'll be adding tomorrow.
RSMLightning25
Richard
Schertz, TX
Network Security
Yessir. I'm hoping they looks as good as I'm envisioning.
Guest
Im sure they will look a lot nicer than those stock running boards!
RUDY
Carlsbad, CA
F 150 Lightning
Self employed
Had mine done about a month ago. I thought I saw/read that you keep everything stock?
C6Bill
2025 F-!50 Lightning 1970 Olds 442
What is the camber kit ? I'd love to drop the rear 3 inches on mine !!!!
MTBAZ
Dan
AZ
22 Lightning Lariat
Did you install the kit on both front and rear? Has anyone tried just installing the rear Springs?
Guest
The Pro Kit drops the rear end 3". Eibach recommends the camber kit in order to properly align the rear end.
