Can Lightning's front grille light bar be turned off independently?
Fordskeptic
Chevy
631Belle#
Chevy, toyota, honda, jeep
I was wondering if the accent light across the hood can be turned off independently. I imagine that in foggy conditions that light will only serve to reduce driver visibility by reflecting off the fog.
sotek2345
Engineering Manager
As far as I know, we haven't heard anything on that, but I suspect it is a non-issue in fog. It is a accent light that doesn't really throw a lot of light forward to bounce off of the fog.
SteffanG
Steffan
Langley, BC
2011 Audi Q5 (written off), 2008 F150 XLT HDPP
Usually daytime running lights will dim down when your headlights are on so it wouldnt be much of an issue.
Pedaldude
Arizona
Mercury Sable's light bar went on and off, so it's possible that Lightning's will too. I don't think that it had its own switch but there must have been a relay and the bar cycled with the parking lights and headlights in some manner. Three decades later, maybe on Lightning, it can be programmed to turn off when the fog lights are on or something will be in the configuration screen.
Ford F-150 Lightning Can Lightning's front grille light bar be turned off independently? 6A07E557-510D-4691-A53A-F887750EE846
BEVolution
Arizona
Model Y adding Lightning
Doubtful, but this is from the PRO
Ford F-150 Lightning Can Lightning's front grille light bar be turned off independently? 0541786B-1BBE-4CF1-BE2F-46A71B2124B7
ShirBlackspots
Charles
Wichita Falls, TX
2006 Ford F-150 XLT 5.4L
That's to open the frunk
The left most button is the bed lamp
Then you have the lighting controls:
Off
Marker lamps
Auto Headlamps
Manual headlamps
Right most buttons: Dash brightness.
