Yakima Overhaul HD bed rack
NY Cowboy
Miami, FL
2021 F-150 Lariat & 2015 Transit T-250
Contractor
Anyone have the Yakima Overhaul HD Bed Rack system set to be just above the cab roof? If so does it make noise. As a contractor sometimes I need to carry a long ladder or some other longer items that don't fit into the bed.
The reason for the Yakima is it fits with an optional mounting kit to mount to the Retrax Pro XR T-Slot retractable tonneau cover for mounting to the bed. But if it makes noise that would not be acceptable.
Seawolf
Naples FL
Ford F150
I'm interested in this as well. Is there any noise with the cross bars just at or slightly above cab height?
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Be surprised if you find any in stock. They are always out of stock it seems.
PungoteagueDave
I have them installed below the cab top to accommodate their kayak carrying system, which then puits the kayaks and the carrying bars above the cab. I would raise them to carry other stuff like long pipes or ladders, but have not done so. However, based on their appearance, I would expect them to be fairly quiet because they are aero-shaped. The cab is very well insulated and we do not hear any wind noise, even with teh kayaks directly overhead. Reposting pics here from other threads to give you some idea of how they look installed. You can see that I have them set at teh lowest level possible, because the kayak carrier system adds enough height for this purpose, but thy can be extended up. Sorry that this does not answer you specific question, but again, they are far enough back that unless you had the windows open, I suspect that even if there were some noise, you aren't going to hear it in the cab.
As noted above, these can be difficult to source, but perseverance will win- I tried multiple options and found the only way to get it done a few months ago (after six months of no-stock failure) was to buy the non-Retrax Overhaul version, which are in stock most places, with the separate conversion kits for the Retrax/Ford OEM assembly. If you look for the Yakima version that is made specifically for the Retrax tonneau, you will not find it, and when I called Yakima, they said it would be more than a year to be back in stock - BUT that the conversion kits did the same job and the combined price came to the same as buying the specific kit for the Retrax. I was able to find them through Amazon resellers, with some of the required bits from REI and directly from Yakima (mine is a bit more complicated than most given the kayak lifting system). I just checked around, see that the tonneau kit is available at etrailer, the overhaul system is available at Amazon
https://smile.amazon.com/Yakima-Ove...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
https://www.etrailer.com/Accessories-and-Parts/Yakima/Y01155.html
Ford F-150 Lightning Yakima Overhaul HD bed rack F150rack
Ford F-150 Lightning Yakima Overhaul HD bed rack F150rack2
Ford F-150 Lightning Yakima Overhaul HD bed rack F150rack3
Ford F-150 Lightning Yakima Overhaul HD bed rack F150rack4
Ford F-150 Lightning Yakima Overhaul HD bed rack F150rack5
Seawolf
Naples FL
Ford F150
@PungoteagueDave - You rock with solid info.
I was at the dealership today ordering my BedRug and RetraxPro XR. Then stopping by my local out-fitter where they have the Overhaul HD sat aside and waiting on me. Looks like I'll get my truck March 2.
Seawolf
Naples FL
Ford F150
https://smile.amazon.com/Yakima-Overhaul-Truck-Bed-Rack/dp/B07MDSP8T8/ref=sr_1_2_sspa?crid=CRXR6UWRZ27U&keywords=yakima+overhaul+hd+truck+rack&qid=1644879447&sprefix=yakima+over,aps,95&sr=8-2-spons&psc=1&smid=A2G7B63FOSFZJZ&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzREU2QjdOSUVPMjVIJmVuY3J5cHRlZElkPUEwMDk2Mzk4M0tSQUFHVVcyMlFPVSZlbmNyeXB0ZWRBZElkPUEwNzY2NDc1MjM0TU9MRUNUNDI1TCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Hey Dave - How long are your cross bars? Thanks.
Athrun88
Toronto, Ontario, Canada
How are these with folding hard tonneau covers? I have a tri fold but would love to get something like this, just worried about clearance when folding/unfolding.
AlaskaMike
'23 Lightning
Check the link, my reply has pictures of it rolled up. A folding cover doesnt stand a chance unfortunately, why I went with the rollup kind.
There are other kinds that have uprights that go straight up, I think Elevate is one.
atxlightning
jesse
2024 Lightning Lariat
i have the Overhaul HD on my Lightning and ive never heard any noise. The bars have been fixed above the roof height for occasional lumber transport, it doesnt seem to impact my Kw/h efficiency based on what i get and others have posted.
180ABL
Western MASS
2023 Avalanche Lightning Lariat ER
I keep mine a couple inches above the cab for ladders or lumber, No issues
Ford F-150 Lightning Yakima Overhaul HD bed rack tempImage2H4pES
atxlightning
jesse
Hey Twin! Same color and rack, but i dont have the tonneau cover. Does that provide you any aero efficiency?
