Tony Burgh
- First Name
- Tony
- Sep 28, 2021
- Western Pennsylvania
- 22 Lariat ER
- Occupation
- Retired
But they have to address the least common denominator. You might be surprised how low that number (consumer) is.Yes. If the manufacturers just gave the numbers battery capacity, range at 70mph, range at 50mph, range at 30mph (cruise control set 100% to 0%) and they gave those numbers at 70 degrees, and 20 degrees then the consumer could plan a trip and properly compare different cars. If it is 0 degrees, knowing to subtract 10 to 20 percent from the 20 degree range and if 110 degrees subtracting 10 percent from the 70 degree range. Don't tell me the mpge that accounts for charging losses (don't charge really slow or really fast. Don't charge to 100 percent and there will be fewer inefficiencies). Just the pack size (useable) and range at specified speeds and temperatures.
