Sync Bugs
neririn
Usa
F150 MachE
Has anyone else encountered the strange error/bug in the lightning UI where you turn up the volume via the dial and all of a sudden it changes from AC to E-heat and turns up the temperature all of the way? Quite annoying, and It seems to be happening to me at least once a week now but I’ve seen it as long as I’ve owned the Lightning.
I have not seen it, but are you verifying you are not dragging a finger across some lower part of the screen and changing it accidentally?
I will note there is magic in the volume button if I recall. It isn't truly turning a physical switch of sorts. If that knob wasn't there you could run your finger in a circle where it is and turn the volume up and down. It is interacting with the screen as you turn it.
neririn
Usa
F150 MachE
While I am not ruling it out, I cant imagine I am accidentally hitting a real setting that is accessible by turning the knob. That said, if no one else has experienced it, it is likely unique to my Lightning, or my finger configuration.
Regular150
Shawn
Purchasing
Try turning up the volume from the steering wheel and see if it does it as well.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there. This sync concern doesn’t sound like something we want you to experience with your F-150 Lightning. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
neririn
Usa
F150 MachE
Conversation sent
