Aftermarket wheels & tires - feedback?
Hrudka
Peter
South Huron, on
2022 Lightning, 2015 Mustang GT, 2015 Jeep Grand C
Machinist
Anyone switched wheels and/or tires on their Lightening? If so was the range reduced somewhat? Debating whether to buy winter tires & rims or try the stock ones.
ScubaSteve
Steve
Missouri
2022 Lightning Platinum, 2021 GT500, 2017 Focus RS
Sales
I leveled my truck and put on some Venomrex 20" wheels and some Toyo Open Country ATII 34s...aftermarket wheel and tire combo weighs 0.6lb less that stock 22" setup. Have noticed MAYBE a 3% difference in range
Hrudka
Hrudka
Peter
South Huron, on
Machinist
It looks like you raised the front end, not lower the back?
F150ROD
U.S. Navy Retired
I’m leveled on Eibach fronts, 20” Rapid Wheels with a +18 offset and Cooper AT3’s in stock size. I’ve lost roughly 6% range or roughly 30 miles.
I am planning on going back to stock, but before I do that I am will see what lowering the rear to stock levels does to range with wheels and tires.
If you don’t commute or take long trips then I think leveling and aftermarket wheels/tires should be fine. But losing range is pretty much working against me. Maybe we need better designed “Aero” truck wheels.
Rob G
Rob
Monmouth County NJ
EQS580, Model X, Cybertruck, Hummer SUT
I’m guessing theirs is much more modest range loss with the lift. What exactly did you do to lift the rear? A level would raise the front if I’m not mistaken.
F150ROD
U.S. Navy Retired
The rear isn’t lifted, it’s stock height. With stock wheels and tires it was a minimal loss of range with just the level up front.
Rob G
Rob
Monmouth County NJ
That's what I was hoping. I really just want the front lifted a bit to get rid of the extreme rake.
F150ROD
U.S. Navy Retired
Yeah I’m still trying to figure out what has more impact on range. It seems that maybe my tires or wheel offset might impact range more than the lift. My aftermarket wheel and tire package is 3 lbs lighter per wheel but my range has still taken a huge hit. It’s either the tire because of the tread type or the offset of the wheel. Could be the wheel design as stock is flat and almost completely covered.
We need aftermarket Aero wheels for trucks lol
Waiting to go back to stock front heigh or lower to see if anything changes.
Rob G
Rob
Monmouth County NJ
From the research I’ve done offset and tire width are big determinants of range. The aero design is somewhat meaning full but the bigger issue is how much tire surface is exposed to generate resistance. The lift will expose a bit of tire height but not a lot so range has a modest impact. Offset may make the tire protrude outside of the fender well and that generate additional resistance and the same for overall width. Rolling mass has a bit lower of an overall impact. There’s a good video using a Tesla that I’ll try and dig up.
F150ROD
U.S. Navy Retired
Awesome! I would love to see that video. It seems that MotorTrend also experienced the same results.
https://www.motortrend.com/reviews/2022-ford-f-150-lightning-wheels-and-tires/amp/
Rob G
Rob
Monmouth County NJ
Rob G
Rob
Monmouth County NJ
I watched it over again and it validates my decision to get 18” rims vs 20”. Perhaps it will offset the loss from the small 2” lift which should be very negligible in the first place.
