Changed to Tremor 18" wheels
tx_lightning
TX
2013 F150, 2022 Lightning XLT XR
I found a set of Tremor take-offs close by in here in Texas. Picked them up one night and had them put on the next day. I appreciate the more aggressive tread for sure.
I have listed my stock wheels and tire for sale in the classifieds.
Ford F-150 Lightning Changed to Tremor 18" wheels PXL_20221006_213922608
Ford F-150 Lightning Changed to Tremor 18" wheels PXL_20221006_214000100
joelb1
joel
colorado
2015 Sierra SLT
Those Tremors look GOOD!
Nice choice.
I was looking at Raptor wheels but ended up with these 20's from an STX
Ford F-150 Lightning Changed to Tremor 18" wheels 20221009_183350
Rob G
Rob
Monmouth County NJ
EQS580, Model X, Cybertruck, Hummer SUT
How have to two of you done on range? I’m leaning toward going from a 20” to 18 for more sidewall.
Also interested to see how those tires change your efficiency. Those look really good.
Oneand0
Mario
South Lake Tahoe
Digital Investigator
I think you’re the second person on here to put on Tremor 18” wheels. These are my favorite so far!
tx_lightning
tx_lightning
TX
I still get 2.0-2.1 mi/kWh average. So no real change.
Update: 1.7 after the swap and a few hundred miles. So a 15% decrease.
Roscoe95
Tim
MA
2022 Platinum delivered!
Any rubbing with those tremor wheels? Did u have to do a lift or otherwise modify anything.. looks good.
tx_lightning
tx_lightning
TX
No rubbing! They are practically the same as my stock 20s.
Rob G
Rob
Monmouth County NJ
I’d think that’s more a function of the tire than the wheels, unless these are wider than stock.
carrillj
Juan
San Diego
2017 Mustang GT Convertible California Special
Government
I don’t like the Lightning Lariat wheels, but I wouldn’t risks removing them. I believe they were designed for efficiency. Plus I wouldn’t want to risk resale value.
tls
New York
2022 Lightning
Be aware that of all OEM wheels for other F150 models, only the 18" HDPP wheels are rated for the much higher weight of the Lightning. There are a number of aftermarket options though.
Pod
2023 AMB Lightning XLT SR
I have a 2019 STX and love the 20” dark pocket wheels on it. Is there any issue swapping those wheels on my new Lightning? Does the weight make a difference? I’ve seen mention of some wheels not rated for a Lightning.
tx_lightning
tx_lightning
TX
I think the only real concern is the tire rating. The wheels should be fine.
tls
New York
2022 Lightning
Again, the only Ford wheels that will bolt up to a Lightning and are rated for the weight are the actual Lightning wheels and the 18" HDPP wheels. Are the other wheels stronger than their ratings? Probably. Is it unlikely you'll routinely load the truck heavily enough that it matters? Also for most owners probably so. But technically you're using components that aren't rated for the application.
anthafied
Anthy
Corralitos
F150 lightning
Firefighter paramedic
What size tires are those? They look great!
