Slight "Click" when starting off either in forward or reverse? TSB 25-2044 Post#253
CallOnColin
2022 F-150 Lightning SR
Anyone have a successful service and fix of this? Were they able to do it in a day? Taking mine in next week and already have anxiety about leaving its side ?
BennyTheBeaver
TSB 22-2395 has arrived.
"Ting, Pop Or Clicking Noise From The Front Or Rear Wheel Hub When Accelerating Or Applying
Brakes (Torque Reversals)
Now you've got something to discuss with your service advisor!
Enjoy!
If that TSB was released on November 28th, is it safe to assume all vehicles being produced since then also have the "Anti-Ting" devices installed?
Mike G
Mike G
N. AL, USA
That's logical...but maybe it hasn't been integrated into the line yet.
CallOnColin
UPDATE: Fix completed using the TSB. Took them a day. Highly recommend getting this taken care of. My ears were trained into hearing it every time I accelerated that it is now jarringly quiet and smooth. Perfection!
data003
Maine
2022 F-150 Lightning Lariat ER (Totaled), 2025 F-150 Lightning Flash ER
Got mine fixed today. I won’t say the clicking is completely gone but I’m starting to wonder if what I’m hearing now is a different click. At any rate it’s significantly quieter than before!
They did all 4 on mine and it took about 4-5 hours.
CallOnColin
Oh interesting. The only other click I have is sometimes when I slow and it switches to regen. That's normal. Glad yours is much quieter though!
data003
Maine
Yeah it’s definitely something with the brake/regen system. Sounds like a relay to me.
Mike G
Mike G
N. AL, USA
I don't think there's any noise when it switches from propulsion to regen...at least there shouldn't be.
data003
Maine
That's actually the whole issue..it's not the regen...it's not a relay...it's the axle halfshafts...and that's why they are adding the spring washer to the stub shafts at each wheel. Did I mention it's free?
I know, I had the TSB addressed at my dealer yesterday. Either the fix doesn’t work or I’m hearing a different click.
Mike G
Mike G
N. AL, USA
Well mine's in there this morning for the fix so we'll see....
Mike G
Mike G
N. AL, USA
data003
Maine
So you're sure they did all 4 axle stubs?
Yes, and I’m sure because the first time I went in to have them install the washers they realized they didn’t order enough and I had to come back a second time. I’m about two hours away from my dealer so, it wasn’t fun ?‍♂
Mike G
Mike G
N. AL, USA
Ahhh..okay...just checking.
The Mach-E forum has seen a lot of posts where the member went in for a front axle halfshaft replacement due to the noise on tight turns.......and then had to go back two weeks later to have the other side done cause the car was still making noise. You'd think they would have checked both sides on the first visit.
