I can’t take this again
bosox8
Charles
Sales
So battery module failure first - truck away for 3 weeks - now battery drain message - will not charge - WTF @Ford Motor Company? Great - now I hope I can get an appointment and a loaner - this is effin’ ridiculous!!
Ford F-150 Lightning I can’t take this again 20F30192-64D8-4530-AC67-BC600C42EB3C
Ford F-150 Lightning I can’t take this again A4F8F4C9-E1A9-4A0D-8084-C2CE558B933D
Ford F-150 Lightning I can’t take this again E1642961-C9CC-4484-8779-C0089D15D09D
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
How long did you have the fixed truck back before you got the new error? If it's just a few days I'd suspect they screwed something up rather than a new issue. Of course I'm just stating the obvious, but had to ask since you didn't mention the timeframe between issues.
bosox8
Charles
Sales
Two weeks - maybe 3
How often are you refreshing the app? That will do it.
Before you make an appointment, I would start the truck, turn the shutdown timer off, get out, lock the door and let it "run" for a few hours to let the LVB charge up.
bosox8
Charles
Sales
Charger is attached and getting blue lights like it’s charging but no change in charge level / miles in 1.5 hours - started at 47 and still at 47 - I do not charge battery to 100% - swear to God either me or this truck is cursed
The battery drain message isn’t the high voltage battery. It's the low voltage battery.
bosox8
Charles
Sales
Good to know - I’ve never opened that compartment - so easy fix - why is this truck so damned fragile?
256fail
Alabama
23 F150 311A XLT
Pilot
Surprisingly , there are a lot of 12V battery issues. Ford had a bad batch on the ICE trucks. I have a feeling they used the same cheap vendor for the Lightning batteries. It amazes me we drive an electric truck, and it isn't set to charge the 12V more than it does? It shouldn't matter if the truck is on or off. A software update could easily fix this and the charge threshold.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
Could be worse, Tesla has "disposable 12V" batteries for a long time.....
antimatterparticle
Higgs boson
PA
Y,150,4XE
your bluetooth is connected according to the picture. How far away is your phone from your truck when parked? If it is too close, it maybe constantly waking up the car. In any case, have the 12v battery tested.
McQueen
Matt
Austin, TX
2001 jeep Cherokee
I also had a battery module replaced. Then shortly after I received the same warning. Turned out the 12v went bad from sitting for so long (also a random freeze event in Texas). They replaced and I still got the drain warning. Came across a random post here that seemed to solve it. Pasted below:
Have you tried resetting the BMS? No disconnecting the battery doesn't reset it.
Reset procedure (no scan tool needed):
  1. Put the truck in accessory mode (push start button without depressing brake pedal)
  2. Flash the high beams relatively quickly five times
  3. Depress and release the brake pedal three times
  4. Wait 3-10 seconds and the battery icon on the instrument panel will flash.
  5. Your BMS is now reset.
F150ROD
U.S. Navy Retired
I’ve gotten that message twice. Took it in the first time and the dealer didn’t have a clue, the second time I just cleared it and went about my business.
