Wide voltage range mobile chargers-suggestions?
eopiela
Eric
Austin, TX
F150
Attorney
I have a 120/240 mobile EVSE https://www.amazon.com/gp/product/B09D6P5MVM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 which has served me well. It works on 120v outlets with an adapter, and on NEMA 14-50 outlets as well. I took it to our ranch today and it errored out with the message "short circuit" which I figured out was caused by the current from the 240v outlet being 265v. I called our electric cooperative and they told me that their standard voltage is 255-265v because of the long distances between substations, and basically said they couldn't do anything to reduce my voltage. Does anyone know of a wider voltage range EVSE I could buy for use there on a 265v circuit?
Holy cow, that's kind of ridiculous. I think most electronics that are dual voltage will be 250v max.
You need a whole home power conditioner, I hope you get cheap electricity.
eopiela
Eric
Austin, TX
F150
Attorney
How far away is the transformer serving your property?
That's apparently part of the problem, the transformer is less than 15-20 feet from the NEMA 14-50 plug, so very little voltage drop due to line loss.
I would be interested in seeing any EVSEs which are designed to work with 250v if you can share.
BennyTheBeaver
AMPROAD iFlow P9 EV Charger Level 2, 10 to 40 Amp, 110-240V Universal EVSE, Versatile for Portable & Wall Charger (NEMA 14-50, 25 Foot Cable)
(Specs list 250v)
https://a.co/d/4RcJkKe
