MM in SouthTX
2025 Lariat PowerBoost with 7.2kW ProPower
3 trips. My combined weight is over 2100lbs to haul for the truck. I estimated about 900-1000lbs per yard of the dirt since it’s been dry here locally. Luckily the nursery is only a mile down the road.
With 1.22 tons I was surprised to find that the shocks still had some spring.
georgepearkes
George
Charlotte, NC
F-150 Lightning Lariat ER
1700 pounds of mulch, handled.
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 E2307B39-27F8-438E-A34D-588700374ABE
MM in SouthTX
That looks like some serious tongue weight. Looks like mine did with 2,440 pounds in the bed. Did you check the onboard scales? Wondering what the scale said and how that would relate to tongue weight. I have wondered whether there is a calculation that could be used to infer tongue weight from the onboard scale.
When I had to get a new trailer for a 27' offshore boat, and figure out where on the trailer to put it, I took it to a scale and weighed it attached to the truck and by itself. The difference is the tongue weight. Should be about 10%.
Max tow weights per 2022 Ford Towing Guide:
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 Screen Shot 2023-04-23 at 6.41.40 PM
suprsprm
Gus
New Jersey
Construction
I’ll check when I hitch up again to dump but I don’t think it was over, didn’t get the weight limit warning. Trailer is probably close to 10k tho maybe a little over.
MM in SouthTX
I’m sure you know what you’re doing if you’re playing with a dump trailer, but the Class IV hitch limit is 7,000 pounds. (Edit—“without the Trailer Tow Package.” Missed that. I guess that’s for the trailer brake controller.) I’ve certainly towed more without a load distribution hitch, and that was in my Expedition. Tongue weight helps!
suprsprm
Gus
New Jersey
Construction
I ordered with max trailer tow package.
Mustang11s
Eric
Indiana
22 MachEauto awd ER XLT Lightning ER
Ford Senior Master Tech
Been waiting for someone to comment. No. Towed it there with my diesel F350. That fifth wheel has an empty tongue weight of 2,400 lbs. would murder a 1/2 ton truck
MM in SouthTX
I hauled two loads of mulch today. The scale does not give me a number, but using the divisions in the green bar, it looks like I used about 65% of the 1,673 capacity, or about 1,100 pounds. That amount of weight did not level the truck. Looks like yours is leveled or a little hood-up. I bet you have 1,000 lbs of tongue weight there. I'm surprised the truck handles that, when the bed only handles 1,673.
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 IMG_4815.JPG
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 IMG_4816
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 IMG_4817.JPG
Its PJ Bia
Maine
F150 Lightning PRO
Went to go retrieve the snowmobiles at camp today. 75mi each way. Temp was in the mid 40s today. Rained on the trip back, heavy at times. Thankfully we have a level 2 charger in the garage up there.
Trip up (empty trailer | 1000lbs)
100%-52% state of charge
55mi est range left
1.5mi/kwh
Trip back (two snowmobiles | 2000lbs)
84%-34% state of charge
34mi of range
1.5mi/kwh
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 20230430_093911
USA EV
USA EV
Yesterday: hauled a couple of upholstered chairs, plenty of room left over.
Today:
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 20230430_154012
>700 bricks
6'x12' dual axle trailer, 55 MPH top speed
Empty, 45° F, drizzle => 1.5 Mi/KWH
Loaded, 40° F, rain => 1.35 Mi/KWH
