2022 F150 Lightning Lariat ER for $56k seems to good to be true. What's the catch?
tksams
Plattsburgh, NY
It's cheap because its salvage title. It'll keep affecting the resale. If it's due to something acceptable to you (IE: not major accident damage), it can be a deal. For that price I'd buy it. Non-salvage carmax offers are 67k, and most used are north of that.
Carmax offers are not that high right now. 55k max for ER lariats (I was there last week).
ivan256
Massachusetts
2022 Lightning Lariat ER
I regularly make a 198 mile round trip at ~80mph in mine on a relatively hilly route (I-90, I-84, I-91). I generally get back with ~15-18% battery. I got home with single digits once when it was 15 degrees out.
You have to precondition if you go in the winter. And if there's heavy rain or snow you won't quite make it.
I wouldn't touch this truck at that price without a rock solid guarantee that the battery warranty is still in effect. If what the original owner is saying is true about its range, there's something wrong with it.
astricklin
99 Mercury mountaineer
It has a lift, and oversized off-road tires. This is why the range is being cut by 30% when driving over 75 mph.
Put it back to stock and I'm assuming it will be back to what everyone else sees.
Amps
Bolt
What kind of tires do you have? That truck doesn't have OEM Lariat ER wheels on it, the OEM tires were A/T on the sticker. But, I can't tell if those are the OEMs, I don't think so. They look oversized and truck looks lifted.
Follow the CarFax item by item. It looks like it was going between Kansas and California during the winter (wind). Then, somebody put 10,000 miles on it in three months between January and April this year. So, it's been on the move not some shop queen..
ivan256
Massachusetts
I still have the OEM "A/T" tires and Lariat wheels.
If it's been lifted/levelled in my opinion I would consider that affirmative for "something is wrong with it"! 30% off the sticker seems like a good starting point for post-modification valuation.
bosox8
Charles
Sales
Are we sure this is actually an ER? HP says 426 hp and ERs more like 585 hp. If so range 230 (EPA) not 320 (EPA).
69kWh
North Carolina
2022 Chevy Bolt EUV
bosox8
Charles
Sales
astricklin
69kWh
North Carolina
2022 Chevy Bolt EUV
Interesting how they have a free Carfax available for their other used lightning but not this one. ? ?
The Carfax was working for it yesterday but mysteriously stopped working after I emailed the dealership to ask for specifics on why the Truck was bought back. Here is the information they sent for it via email:
Here is the Ford Warranty report for the Ford F-150 Lightning you are interested in. This details ALL the work that Ford did to the vehicle under warranty. This includes any recalls and any reason to bring the vehicle for service, as well as any reason for the buy back.
I would love to answer any questions for you that you have about this report and to make sure this vehicle is still available for you when you want to come in. Speaking of that, when would the best time be for you to come in and look at this vehicle?
Detailed Vehicle Specification
VIN1FTVW1EV3PWG04633
Vehicle LineT/FDMarket Derived CodeF
Body CabT/BCVer. SeriesT/GR
Drive TypeT/E
PLT CDEHTRS CDT/WAENG CDT/RC1
Production Date22-NOV-2022Warranty Start Date11-FEB-2023
Selling Dealer124204Selling CountryUSA
GSAR Claim KeyTrx CodeTime In ServiceLabor HoursDealershipDIST (Miles)Repair DatePrefixBaseSuffixDoc
Details2474521127.4FORD SPRING HILL63528-FEB-2023NL3Z10D672A400042A
Customer Comments(CONTACT 119872499) CUSTOMER STATES WRENCH LIGHT IS ON WARNING FOR POWERTRAIN MALFUNCTION REDUCED POWER FAULT IN HIGH VOLTAGE SYSTEM CHECK AND ADVISE /// BEGIN TECH - INTERMITTENT AND NOT CURRENTLY ON CHECKED CONNECTED VEHICLE DATA OVER LAST CALENDER MONTH BECM POAA6:00 SETS AND CLEARS ALONG WITH OTHER LESS RELEVANT TO CONCENR CODES PRINTED ALL RESULTS NO APPLICABLE OASIS MESSAGES OR TSB WSM 414-03A PINPOINT TEST S REFERENCED ALTHOUGH CONCERN NOT CURRENTLY HAPPENING BECM DETECTED AN HV ISOLATION RESISTANCE VALUE LESS THAN 400000 OHMS FOR 30 SECONDS PINPOINT TEST S1 NO FREEZE FRAME SHOWS 362475OHMS S2 YES INTERMITTENT S3 LIVE BECM DATA LOGGER PIDS CURRENTLY PIDS READ +9000000 IN SERVICE BAY S17 NO HEATER NOT CAUSING S18 NO A/C COMPRESSOR NOT CAUSING S19 STOP HERE RAISED VEHICLE TO INSPECT NO VISIBLE DAMAGE LOWERED AND TEST DROVE 15 MILES AT ALL DIFFERENT SPEEDS AND LOADS NEGATIVE BUS RES DID NOT LOWER PAST 897K OHMS A19 RESUMED NO CHARGE PORT CONNECTION OK S21 120V DEVICE IN FRUNK OK S22 DUAL MOTOR SYSTEM 120V DEVICE IN BED OK CONTACTED HOTLINE DUE TO NO VISIBLE ISSUES WITH CABLES KEYED ON LATER IN DAY WRENCH LIGHT ON SELF TEST LIVE P0AA6 WITH FREEZE FRAME VALUES OF BATT CUURENT 1.2 AMPS NEGATIVE AT 210225 OHMS CONTACTOR AT 835850 AND POSITIVE AT 1223900
Tech CommentsHOTLINE DIRECTIONS GIVEN AND FOLLOWED SWIS CALL APPOINTMENT SETUP REMOVE HV BATTERY AS PER ALL INCLUSIVE WSM DIRECTIONS BATTERY HEALTH REPORT TAKEN JUST BEFORE REMOVAL AND WRENCH LIGHT WAS ON DE-ENERGIZE HV SYSTEM THEN PROCURE FOLLOWED BATTERY REMOVAL HOTLINE SWIS REQUIRED TO MOVE FORWARD (ENG) SWIC CALL WHILE DISASSEMBLING REMOVING 6, 7, 8 ARAYS AFTER ISOLATING ALL ARRAYS #1 ON NEGATIVE POST HAD APPROX -12V INDICATING VOLTAGE LEAKING OUT OF NEGATIVE SIDE TO CASE HENCE THE ISOLATION FAULT REFERENCED EFC 10038 ORDER #1 ARRAY KIT TWO TA38B TUBS OF TIM COOLANT DISTILLED WATER AND ANY OTHER OTU PARTS LISTED IN WSM VOLTAGE CODE PRINTED 0F5B74 MED.V.3.93IV NEW ARRAY PREPPED NEW (UNBAOXED) ARRAY PERFORMED ARRAY BALANCE PROCEDURE USING XMB-9640 REMOVED OLD #1 ARRAY FIRST ARRAY CHARGE RESULTED IN OX24 ERROR/FAULT DISCONNECTED ARRAY FROM BALANCER RECONNECTED ALL CABLES AND RESTARTED BALANCE PRINTED ERROR PAGE AND NORMAL BALANCE RESULTS INSTALL COLDPLATE SETUP TIM GUN INSTALL/APPLY TIM INSTALL ARRAY AND PRESSURE TEST COOLING SYSTEM INSTALL BATTERY COVER SETUP VACUTEC PRESSURE TESTER SETUP VENT COVER WITH TAPE FOR TEST PERFORM PRESSURE TEST WITH FITTINGS VERIFIED NO CASE LEAKS RAISED AND BOLTED BATTERY ATTACH CONNECTORS ATTACH ALL SHIELDS FILL COOLANT SYSTEM FDRS CLEAR CODES FSE INBOUND CALL UPDATING STAUS BEGAN COOLANT SYSTEM FDRS PURGE TAKING 1.0 HOUR (TIMED) SUCCESSFULLY COMPLETED TEST 18 MILES OK AT 50% BATTERY TOPPED OFF CHARGE UNTIL CUSTOMER PICKED UP
Details247938110FORD COMPONENT SALES, LLC63508-MAR-2023NL3Z10D672AHVB6461
Customer CommentsDealer RO number 400042
Tech CommentsDealer RO number 400042
Details31025123H0128.2FORD SPRING HILL66921-MAR-2023*10D672*400834A
Customer CommentsCUSTOMER STATES WRENCH LIGHT IS ON, WARNING FOR POWER TRAIN MALFUNCTION,REDUCED POWER,FAULT IN HIGH VOLTAGE SYSTEM, CHECK AND ADVISE
Tech CommentsVERIFIED STOP SAFELY NOW AND WRENCH LAMPS DISPLAYED WILL NOT RESPOND TO THROTTLE INPUT P0B24 IN BECM UNABLE TO PERFORM BECM HEALTH TEST AT FIRST FOUND ARRAY #9 HAD ONE CELL AT 3.68V COMPARED TO OTHERS AROUND 3.88C NOTIFIED FSE WHO COMMUNICATED WITH ENGINEERING AT FOMOCO PINPOINT TEST AP PERFORMED IN WSM 414-03A AP1 NO AP2 YES 45% AP3 NO AP4 YES 0.2V CELL 95 ARRAY #9 AP5 AND AP6 REPLACE ARRAY #9 ASSEMBLY ENGINEERING TEAM INSTRUCTED FSE AND TECHNICIAN TO CLAIM 23H01 TEST DROVE AFTER ALL WSM INSTRUCTIONS FOLLOWED WRENCH LIGHT CAME ON NO DRIVEABILITY DDR4 DISTANCE CORRECT
Details3184071212FORD SPRING HILL66921-MAR-2023NL3Z7P500A400834D
Customer CommentsADD POST BATTERY ARRAY REPLACEMENT FOR 23H01, WRENCH LAMP ON WITH NO DRIVABILITY. SOBDMC DTCS. DDR4 MILEAGE ACCURATE
Tech CommentsWRENCH LIGHT FOR SOBDM-C DTC P07BB P26C3 NOTIFIED FSE AND WORKED DIRECTLY WITH TO EXPEDITE DIAGNOSIS NO OASIS MESSAGES PINPOINT TEST N FOLLOWED WSM 307-05A N1 YES CODES PRESENT N2 ACCESS C4050 (LIFT VEHICLE) YES 5V PIN 12 N8 ACCESS C3471C AT COBDMC YES 0.4 OHMS C3471C PIN 28 TO C4050 PIN 6 N9 YES C4050 PIN 6 TO GROUND GREATER THAN 10K OHMS N10 YES C4050 PIN 6 AND 5 NOT SHORTED TO OTHER CONNECT PINS N11 YES C4050 PIN 19 TO C3471C PIN 29 AT 0.4 OHMS NOT SHORTED / OPEN INSTALL NEW REAR DRIVE ASSEMBLY ADDITIONALLY CHECKED C4050 PIN 12 TO PIN 17 SAME 5V NO CHANGE FROM NORMAL GROUND RE-RAN SELF TEST TO VERIFY STILL ON DEMAND STATUS ADDITIONALLY KEYED ON AFTER RECONNECTING DATA LOGGER SOBDMC RANGE POSITION PIDS DTCS STILL ON DEMAND TR_PARK A AND B PARK A=6% B=0% NEUTRAL A=82%B=0% VERIFIED PINPOINT TEST CIRCUITS AND COMPONENT TEST RESULTS REPLACED REAR DRIVE UNIT PER WSM REQUIRED TRANSFER OF SOBDM-C AND ASSOCIATED OTU PARTS AND PROCEDURES FILLED DRIVE UNIT WITH FLUID PERFORMED SOBDM-C ELECTRIC MOTOR RESOLVER OFFSET PROGRAMMING FILLED AND RAN BECM ELECTRIC DRIVETRAIN 60 MINUTE BLEED PROCEDURE TEST DROVE TO 680 MILES (APPROX 7 MILES) WITH NO ISSUES TOPPED OFF MOTOR FLUID AFTERWARDS PLUGGED INTO WALL CHARGER FOR BATTERY TOP-OFF CHECK TOPPED OFF OK TEST DROVE OK NO FURTHER CONCERNS FOUND OR PENDING
Details24793723H0120FORD COMPONENT SALES, LLC1022-MAR-2023NL3Z10D672BHAR2101
Customer CommentsDealer RO number provided by dealer
Tech CommentsDealer RO number provided by dealer
Details394769PRENT30FORD SPRING HILL67008-MAY-2023*RENTAL*402458A
Customer CommentsLONG TERM RENTAL GCCT CAS-42684515-X7X0C0
Tech CommentsPRENT RENTAL REFERENCE RO 400042 DATED 02/28/2023 AT 635 MILES, REFERENCE GCCT CASE CAS-42684515-X7X0C0, REFERENCE ENTERPRISE RENTAL 20924/90T7XS 57 DAYS TOTAL $2867.00
Details56268423B2140.4PARKS FORD OF WESLEY CHAPEL70618-MAY-2023*14G490*08810304
Customer Comments23B21 GATEWAY MODULE PROGRAMING
Tech Commentsperformed fsa 23b21. programmed gwm to latest calibration
Details562648RAVIN41PARKS FORD OF WESLEY CHAPEL70618-MAY-2023*RAV*08810302
Customer CommentsMULTIPOINT INSPECTION
Tech CommentsMULTIPOINT INSPECTION
Details562664RAVIN41PARKS FORD OF WESLEY CHAPEL70618-MAY-2023*RAV*0881031
Customer CommentsFORD REAQUIRED VEHICLE PROGRAM - RAV BUYBACK VEHICLE. VEHICLE COMING IN FOR FORD REACQUIRED VEHICLE PROGRAM. RAV BUYBACK. VEHICLE COMING IN FOR wrench light on dash
Tech Commentsinspected vehicle for a wrench light. no warning lights on at this time. eec tested, no dtc`s. checked oasis, no tsbs or ssms. visual inspection ok. performed 16 mile road test using fdrs for pid monitor, no fault pids. no warning lights or other driving characteristics unable to duplicate concern of wrench light. eec test ok, road test ok. reviewed warranty history, found previous dealer to have made repairs for this concern already
Details562601P8643PARKS FORD OF WESLEY CHAPEL70618-MAY-2023*RECAL*0881035
Customer Commentsprogram all modules per fse
Tech Commentsprogramed all modules per fse
ChrisCon
The Hamptons, NY
Hi Everyone---
Just wanted to mention to all of you that @cybertruck was the previous owner and has posted on here about the truck, so all of the speculative posts might as well be "You should read the comments"...
Regarding the listing saying 426HP, I see that many ford dealers incorrectly list this on extended range models including my local for dealer. Might be an error on Ford corporate's end.
3rdgenfan
Geoff
Delaware
Cybersecurity
Wow! We're you towing something? This is a great vehicle for my needs but it is with a fair amount of trepidation I plan my trip to Maine with two other bodies & a Saint Bernard in a few weeks. Taking the "Western Route" thru Allentown and up to Tappan Zee vs the 95 / Turnpike Route due to the exce$$ive tolls / bridge crossing and I've planned each of my charges at about 200 highway miles apart.
I've been trying to plan my trip to Maine this August and realized I'll give it another year since we don't have any way to charge my truck once we get there, and instead I'll rent an SUV for myself, my GF and our 7mo Golden.
Let me know how the trip goes, and maybe it'll fix my confidence!
