dust cap for FCSP cable
Ffxdude
22 Lightning Lariat ER
Computermedic78
NY
23 Lariat ER
3D Printing Product Manager
I'm not sure what fits a DCFC cable will also fit the FCSP. heres my FCSP with my dust cap. seems plausible, I dunno! but when I 'm out and about in the next few days I'll try and remember to take my cap with me and stop by a local DCFC and see it it fits. will post results.
They both use the CCS standard so they should be the same.
Ffxdude
Works perfectly as expected on the FCSP handle @Computermedic78 thanks for posting the printer file. Id be happy to email a $5 ExxonMobil gas Starbucks card if you want to dm your email address...;)
Ford F-150 Lightning dust cap for FCSP cable 1000234952
Computermedic78
NY
23 Lariat ER
All good man I'm glad it's working for you. If you have a printer there's no reason to pay me, I listed it as open source.
Stang68
NJ
Mach E GT Performance, Lightning Lariat Extended
I was able to check fitment at a local DCFC this morning.
For those of you with a 3D printer the STL can be found here:
https://www.printables.com/model/667911-ccs-dust-cover
For those without a 3D printer, it can be found here:
https://matts3dprintables.etsy.com/listing/1611578826
Would you say this is strong enough to mount to a wall and support the Charge Station Pro handle? I am installing our FCSP soon and we want the unit inside but the handle likely outside, and there's aren't many CCS1 holsters available.
Computermedic78
NY
23 Lariat ER
No I don't think so. I can make something g that does, but I thought the FCSP has a holster built in.
Stang68
NJ
It does but if I was looking for an option to have the connector stored separately on the wall from the FCSP then something like what you printed would be useful.
Computermedic78
NY
23 Lariat ER
I'll put something together, just give me a day or two.
Computermedic78
NY
23 Lariat ER
Where are you looking to mount to? Just straight into a wall?
roadhouse
F150 Lightning Lariat ER
I'm in the same boat as you. I bought this regular J1772 holster and cut out the bottom notch to fit the DC connectors. It works great after being trimmed up a bit! Can grab a picture tomorrow if you'd like.
It doesn't cover the DC connectors, but they're pretty much flush with the wall once everything is mounted. It's undercover so I'm happy with the result.
Stang68
NJ
Computermedic78
NY
23 Lariat ER
Let me know what you need/want changed. If you have experience I can put up the fusion files too so you can make your own changes.
Stang68
NJ
Thanks, still working out exact placement because SunRun is dragging their feet in shipping out the charger. Will be in touch!
