Cruise control and speed limit signage
Jodster
Hugh
Parksville B.C.
Mercedes Glk 250 diesel
I drive usually 10% over the speed limit and everytime I pass a speed limit sign, cruise control reduces the
speed to the posted speed.......went into setting to try and turn this feature off, but can't find the off button
Any ideas?
[email protected]
awilli1010
SE Michigan
Any ideas?
[email protected]
Turn off speed sign recognition
Basis0439
2023 F150 Lightning
Of course if you turn that off, your blue cruise won't work.
Steveel
Steve
Washington
2023 F150 Lightning ER Lariat
Mechanical Engineer
You can go under Driver Assistance, Speed limit Assist, Tolerance, and slide to 10 over. That might stop it.
(My issue was I usually set cruise control at 68 and it sees the 80 sign and wants to go up. I usually hit the cruise minus on the steering wheel and it stops it from going up to 80 and ignores it from then on.)
Steveel
Steve
Washington
Mechanical Engineer
Well I tried it, Speed limit assist does not change cruise control, onlly the warning. When it sees a sign I just adjusted on the steering wheel and it ignored the signs from the on. Not the best solution.
