Turn off passenger air/heating 2023
Stanjj
Stan
Alabama
2023 Lightning
Consultant
My wife is cold nature and I need a quick and easy way to turn off her vents. Simple answer needed. Thanks
Driver-Focused mode only turns off heat to the passenger side IF no one is sitting there. It is to help you reduce e-heat usage by automatically disabling passenger heat when no one is there.
From the owners manual:
Ford F-150 Lightning Turn off passenger air/heating 2023 1710554336323-m7
If A/C blowing on her is the problem, you should turn off the upper vents on the passenger side.
