F150 Lightning FORscan thread
I was not aware of that tool - very nice. Its been about a month since I had an update, I'll take the opportunity to download my latest file as it exists.
You can load up to 4 files and it will show differences in red. Works with either FORScan .abt files (which you have to save one module at a time AFAIK), or the Motorcraft .ab files.
  • Love
ktn
MN
2023 F-150 Lightning® LARIAT ER
your settings worked for me to have cameras at speed, however, it goes to the camera as soon as i go into drive mode... any way to change that?
Did you ever solve this?
I edited my comment some so sorry for that.
My original save files are from about a month ago and I have not received any updates since then (that I know of anyways).
Did you have the dealer do the Front Sensor CSP? That changed the IPMA dramatically.
tannerk89
Tanner
Roanoke, VA
2023 F-150 Lightning Pro ER
Automotive Engineer/Product Owner/Project Manager
Bought my Pro Monday and by Saturday had enabled glare free thanks to this thread.
Ran into a small issue. Lane centering button no longer works on the steering wheel. I need to confirm all of the as-built values that I changed match the instructions, particularly the SCM update. But, the glare free option was enabled and working fine so just a minor inconvenience to work through!
21st Century Truck
Martin
Here is a FORScan mod I applied a few days ago that I really like. The Lightning is annoying in that if you turn the truck on without your seat belt buckled, it chimes 4 times. (My routine is to hop in my vehicle, turn it on, then buckle my seat belt while it warms up (ICE) or boots.)
This mod changes the seat belt warning type from US to European. Now you get no chimes when starting the vehicle unbuckled. But you still get chimes if you start driving without being buckled (at an increasingly annoying level). Can't say if that part is any different.
IPC: 720-01-02: xxxx x2xx
Note this assumes the previous value was 0. If your value is different than 0 then add 2. Always refer to Livinitup's spreadsheet if unsure.
Thanks for this mod. I applied it today and I like it a the lot.
With the Lightning, it's easy to sit in the truck while it's ON and either do real work or play with Forscan etc, and now the seat belt chime doesn't ding until the truck actually moves.
BTW - in Reverse, the new seat belt chime also doesn't ding. The truck had to be moving forward.
SNBI18
NJ
24 Lariat
Has anyone figured out how to turn off the headlight lamps for the DRL, so that only the light bar illuminates when the DRL is on?
21st Century Truck
Martin
I think that the center rectangular small headlight component IS the "DRL". At least, on my Lightning truck.
21st Century Truck
Martin
Strange, I have a 24 lariat. My DRL is the light bar AND the small rectangle headlight.
Hmm I do wonder whether this is a trim level difference.
I adjusted my DRL strength (based on FORScan info on this forum) twice, from the OEM 10% up to 75% and then back down to 25%. I always check it at the plate glass front windows of the Mercedes dealership down my road.
That's how I know that in daylight, my "Daytime Running Lights" are just the two small center rectangle lights in my three-light matrix wig-wag LED headlights. The unibrow lightbar is dark on my truck until darkness.
Now, for clarity, I did turn on the glare-free function on my headlights, a fantastic feature BTW, and perhaps this has altered my Daytime Running Lights?
SNBI18
NJ
24 Lariat
I've never seen a lightning without that bar on during the day unless the DRL will shut off from the infotainment system. When the truck was new do you remember the bar ever being on during the day with the drl? My cousin has a 24 XLT and his DRL is the rectangular light plus the light bar.
21st Century Truck
Martin
Hard to notice when I'm driving haha... but once I started monkeying with the DRL intensity setting and checking in the Mercedes plate glass windows, I assure You that in daylight, just the central rectangles are ON. Therefore, I started to think of those rectangles as DRL.
I actually looked for Ford's definition of DRL for our Lightnings based on a similar discussion with another member here, but I gave up after a while... just not worth my time for more than 15 minutes of searching. Maybe someone here can clarify what is Ford Corporate's official "DRL for the Lightning" definition.
The light bar is on during the day when the truck is not in park. The light bar is NOT part of the DRL's - at least not from a control perspective. You can not adjust the brightness of the bar. It's been proven too many times and last year it was discovered how the light bar is powered. Each half gets power from the headlight on that side of the truck. You turn the power on or off to the light bar through SW of the headlamp.
If you think you are adjusting the brightness of the light bar you must be doing it in two places - each headlight.
21st Century Truck
Martin
Hey Greg!
SNBI18
NJ
24 Lariat
Got it so to get the light bar to light up you must have the two rectangular lamps on that are in the headlight and also display.
