Truck charge exceeding limits set. Anyone else?
Laxputs
Shopping
At my home I set the charge limit to 85% in the Ford Pass app: both in the One-time Max Charge and the Target Charge. In the truck I also set the One-Time Max Charge to 85%. I do not have any charge settings set on my Chargepoint Charger. Yet the charge went past 85% to 100%. This has happened twice. Anyone else experiencing this glitch in the truck exceeding the stated charge limit? Or perhaps I'm doing something wrong? Thanks.
Delete your home profile today.
Once your SOC is below your requirements, create a new Home profile as you begin a charging session, do it in the truck on the Sync screen.
Make sure to accept any GPS coordinates or suggested address location even if it's not your actual home address, set the parameters and save.
I had that happen before I realized I need to set up the charging on the truck menu to use the station I had set as "Home" with the parameters I had set there.
Otherwise it defaults to 100%
