Ford Pass App Charge Station Pro Amp Adjustment Setting Useless
IWIRE
Nick
2023 F-150 Lightning Lariat
Electrical Consultant
Well at least you have an app.
Us with the Juicebox charger now have no app at all.
Rick
I am looking for an EV Charger that uses my excess solar in real time to charge my EV. The Enphase IQ does it in 25% increments adjusted every 15 minutes, but I want something more responsive, and with the FordPass App if it worked I could tweak it to be close most if the time.
My JB app is still working...for now :sadface:
Ford told me the amperage adjustment feature does not work anymore in the FordPass app, even if I rebooted the charger. Not sure why the feature is even exists in the app.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
I have the Beta test version of Ford Pass & can confirm that my version of the Ford Pass will let me adjust the Ford Station Charger in the app - see below. I couldn't get the Ford Station Charger to talk to Ford Pass until just recently. I've been able to adjust the Charger ever since.
Ford F-150 Lightning Ford Pass App Charge Station Pro Amp Adjustment Setting Useless 1730519558421-7v
Golieguy64
Jason
Wisconsin
2023 F150 Lightning Lariat ER
How do you get access to the beta app? I am able to change this slider, and it shows success in the app, but it doesn’t change anything. Turned the breaker on/off a few times and still can’t get my charger to go to the full 80. Internal dial is set properly and I used to be able to control the rate from the app.
bthanos
2023 F150 Lightning Platinum
System Architecture (retired)
When I first installed CSP I set the HW dial to enable 80 A . When I connected to the car it maxed at 6 KW and amber led was lit while charging. I went into the Charger Settings from FordPass and noted the max current was set too low (25 A). I dragged the slider up to 80A and max charge is 16.7KW. So I know there is some connection working now in the app for current setting. Just set to 80A and left it there.
Golieguy64
Jason
Wisconsin
Yea I was charging at 80 for a few days, and decided to lower it to like 50a because I didn’t need all the speed and I knew I could just dial it up in the app…silly idea I guess haha.
bthanos
Figure I paid for 80A so i wired to do so. Right next to main panel and short #2 copper wires.
Ford F-150 Lightning Ford Pass App Charge Station Pro Amp Adjustment Setting Useless IMG_2283
Without acknowledging anything, don't waste your time chasing the beta version. It still doesn't work.
