A few questions about lowering
UglyXLT
2023 XLT
I’ve done a bit of research on this and I see that many of you as well as myself are not too fond of the rake angle on the stock truck. I’ve seen a number approaches to lowering the truck but which method is the most cost effective in achieving the street truck look? I’m pushing towards ordering the belltech 25001 struts while keeping everything else stock for the rear. If I do this, what’s the best tire and wheel size for filling the gap up some more?
I would love to do the icon lowering kit but I can’t bring myself to drop $7k and then have to buy wheels and tires on top.
davehu
hot springs, AR
good luck. One of the few complaints I have about my Lariat is that it sits about 4" higher than my 10yr old Chevy Avalanche. Sure glad I bought running boards as it would be very uncomfortable to get in without them. (and I'm 6ft tall)
What all would be needed? Thanks for any help btw
Probably the Icon kit. The best you will get in the rear with shocks only is about 3 inches, and that is with the camber kit. About 1.5 inches with shocks only.
UglyXLT
2023 XLT
Noted, I was just now browsing around on the forum and I like the way the user on post #22 in this link set their truck up as well which is similar to what I'm trying to do. So I may go that route
Lowering Lightning height by a couple inches | Page 2 | Ford Lightning Forum For F-150 Lightning EV Pickup: News, Owners, Discussions, Community
There is a video link on here somewhere about installing the air strut tank into the frunk. Look around for it. Makes for a clean install, but you lose the frunk functionality.
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
I've done Belltech AND Icon full kit.
Bottom line: Don't do Belltech if you aren't going to install Icon camber plates. Even a 1" rear drop with Belltech gives you unacceptable 3 degree camber, adversely affecting handling, noise, tire wear. Belltech shocks also wear out and can't handle the weight of the truck. It rides ROUGH too, because the stock spring is variable rate which means the top 2-3" of compression are 95% of your comfort. If you remove that by compressing with the Belltechs, the rear rides incredibly stiff in addition to the camber problem. It's like riding on a flatbed.
Icon kit is expensive but it's designed to work with this truck. It has a wide range of settings and can give you an OEM alignment once lowered. I've dropped mine all the way down, lifted it some, and through trial and error have the ICON kit right in the sweetspot of comfort and performance (handles MUCH better).
I've done articles on both Belltech (avoid) and Icon ($$$). I did another article on ideal Icon looks and settings to balance handling and comfort. I'm including the one I wrote on the Belltech and some of the physics of why it doesn't work.
I'm also including a link to my ICON write up.
I don't think anyone has done more suspension work on a Lighting than me, except maybe one of the guys that hates money and put bags on it (which is also a terrible idea.)
So, what would I do?
1) Get the Icon
2) if you don't want the Icon, get some Fox or other high quality shorter struts and replace all four corners, install ICON camber plates, then get an alignment
3) Do nothing and enjoy a comfortable OEM suspension (yes, I hate the rake too)
Included are some pics of mine.
Ford F-150 Lightning A few questions about lowering Photo Collage Maker_2024_12_20_09_18_19
csukoh78
Nope
SE USA
1) Get the Icon
I've made some changes since then, such as going to black wheels and getting rid of the ugly stock running boards for some retractables. MUCH better
UglyXLT
2023 XLT
1) Get the Icon
Thank you so much for this.
UglyXLT
2023 XLT
No worries. Here it is with Black wheels, running board delete, and ideal ICON height.
Last question. What are the specs of the wheels and tires? Also how do they impact the speed reading and range?
csukoh78
Nope
SE USA
VenomRex VR-604. My third set of VenomRex. Love them. Lightweight, saved 11-12 lbs per corner compared to stock. Drastically improved mileage in city and sub-highway speed. Equivocal at highway since momentum keeps them spinning and somewhat less aero than stock. Overall between lowering and getting the lighter weight wheels, I got a 10% improvement (2.2->2.4) over 11,000 miles in all seasons
