DRIVER DOOR NOT FLUSH
TitanGuy
carlos
Los angeles
2024 Lighting Lariat Antimatter Blue
Sales Rep
I've seen a few threads on this issues with multiple solutions. The top corner of my driver side door is proud about 1/16 of a inche. That does not bother me. But was has been very annoying is the rubbing sound I hear when I hit a bump. Also at higher speeds I have had air leaking out of the door. I tried to bend it myself and it seemed to work for a day. Today was the last straw, hit a pothole on the freeway at about 55. It sounded like the door opened. I could hear the shift in the weather stripping all around the door. Before a take if to the dealer want to hear from some of you on what to expect. FYI I have a 24 lariat less then a month old.
I'd bring it in, maybe the body shop has a procedure for tweaking the mounts & striker so that it closes correctly.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
pongdyla
Dylan
Katy
F-150 Lightning Lariat
I have the exact same issue! May I send you my VIN so you can look into it as well?
