This will be my last attempt at a Lightning Road Trip
evowner
Frank
SW Ohio
Retired EE
I mean, every EV will charge to "100%". That isn't in any way a measure of if what you are doing is working. Even Leaf's with huge degredation charged to 100%. That's kind of what folks mean with "the forum disagrees with you"...
As I said I still get the same amount of capacity and range out of that battery as did many years ago.
RustleT
Russell
Roseville, CA
2023 Ford Lightning Platinum
CFP
I want to share a few thoughts for those unfamiliar with ABRP or using it without exploring all its settings. ABRP is excellent for customizing based:
  • On your driving habits (I drive like a bat out of hell and don't care about efficiency ??),
  • How much off-route detour you’re okay with to get to the charger (they call it charging overhead)
  • Real-time weather conditions
  • Your desired state of charge (%) upon arriving home and at charging stations. (I push mine down to 10%)
  • Your preferred charging networks
  • and much more
What I discovered about ABRP is that it's best not to resist its guidance to extend your range unnecessarily. Once set up correctly, it calculates the quickest route by factoring in numerous variables. You can test this by adjusting your settings and observing how the charging plan updates.
For example, during long trips, I often pushed to use more battery with only two stops, but following its guidance and stopping earlier—sometimes significantly earlier—and following its recommendation for three optimal shorter stops proved to be faster. It becomes clear once you appreciate all the factors involved.
By the way, for current users, please upload photos of charging stations to ABRP. This is incredibly helpful when selecting a Tesla station, especially since some older Supercharger locations with shorter cables and the charger placed at the back pose challenges for us Lightning drivers. And no, ABRP didn’t compensate me for sharing this. Anybody got a contact? ???
John Becker
Cincinnati
2023 F150 Light'g Lariat SR, '18 Audi S5 Cabriolet
  • and much more
How much of this applies to the free version?
RustleT
Russell
Roseville, CA
CFP
Good question. I had to log out since I pay $50/yr for the premium version. A lot of it is available for the free planner. The premium integrates real-time data as you drive through a combination of weather reports, traffic reports, current charger availability, and a live feed from your truck via an OBDlink.
So:
  • Free: Plan with it and manually adjust as needed while on the road.
  • Premium ($5/mo or $50/yr): It will automatically adjust while you're driving.
