Blind-Spot camera with turn signal
PJnc284
Garner, NC
The ICE values won't always work for the Lightning. Well it works for side view but may disable Lightning specific features depending on year and trim.
True. Like the changes we were using here to enable the APIM toggles for the new BC features were disabling KDA on the Lightnings until you caught it. lol
I remember that. Luckily it was a seldom used toggle. Feel free to bounce off me on anything you find out in your "lab" as it might relate to Lightnings.
I'm slowly building up data on the 25's. So far have a bunch of Pros (I think that's all they made the first month) and one Flash. Starting to see some different factory values for some of our mods that may require editing the recipes for a 2025.
F150ROD
U.S. Navy Retired
Had this on my 2017 Honda Civic, good feature but rarely looked at it to be honest.
CyclopsThere
Portland
2023 XLT
PJnc284
Garner, NC
I just snagged this adapter-- how did you get everything working? Just use the default trailer?
I configured it as the smallest trailer possible. Still dropped the GOM pretty good but I didn't drive it enough with the adapter for it to adjust.
CyclopsThere
Portland
2023 XLT
Wonder if I don't get that functionality due to XLT/small screen. Didn't work out for me last night. Oh well not a big hit to the bank :)
Did you make the FORscan changes outlined above? If so, what values did you change?
For a 23 XLT:
IPMA 706-01-02 *xxx xxxx xx-- change 0 to 3 (turns on functionality)
APIM 7D0-02-03 xxxx x*xx xx-- change 0 to 8 (adds toggle in Sync menu)
CyclopsThere
Portland
2023 XLT
For a 23 XLT:
Reading comprehension not my strong suit :) I was hoping this would magically just work with stock.
Time to dip into Forscan (after reading & comprehending)-- thanks!
Also note it does require an IPMA update from 12/23 See earlier post. If you had the parking sensor CSP done, you should be good.
CyclopsThere
Portland
2023 XLT
sweet- i did indeed. just have the latest mechanical recall to take care of
