Startup/shutdown sound on Platinum
Woonkie
Woonkie
Adam
Las Vegas
2023 F150 lightning platinum
Try a Sync restart if you haven't already. With the truck running, press and hold the volume down and the skip right buttons on the steering wheel simultaneously for about 10 seconds until the screen restarts. That will restart the Sync and hopefully clear its brains.
done that, also disconnected the battery for 20 mins
Adventureboy
I think you've done all you can on this one. Your truck is still under warranty so maybe a dealer visit would be next.
Woonkie
Woonkie
Adam
Las Vegas
Thanks for the help, Dealer is useless on this issue.
The startup sounds that are supposed to be playing every time are not playing. is the issue
The sounds in the video you posted are only active if your seatbelt is unbuckled. If your seatbelt is buckled when starting and the truck makes no sounds that is what it's supposed to do.
If a buzzer sounds behind the instrument panel on startup there is an issue.
abcut973
Anthony
Denham Springs
I have the same sound at startup. Car just had several updates at the dealership including the front parking sensor thing so it is recall free. It is 2022 EV blue certified . Got delivered yesterday and noticed the sound.
I didn't have my seatbelt on so could be the reason?
Woonkie
Woonkie
Adam
Las Vegas
buckled or unbuckled doesn't play. only the old school sounds
Woonkie
Woonkie
Adam
Las Vegas
yes they all play them. Mine doesn't at all except every once in a while
Woonkie
Woonkie
Adam
Las Vegas
Just did a speaker test from the Bezel menu, I don't think all the speakers are working
What sound? There are two possible sounds. Nice sounds and old school buzzer sounds.
Which speaker isn't working? If it's a door speaker you can try reseating the wiring harness. Or you can just take it to the dealership and let them worry about it.
Woonkie
Woonkie
Adam
Las Vegas
taking back to the dealer this week, when I do the speaker test it doesn't list all 18 speakers, and the sounds on some of them are so low, I can't hear them at all. I bet this is the issue.
At some point the Platinum was decontented to fewer speakers. I don't recall if it was 2023 or 2024. Probably worth investigating before taking the truck to the dealership.
Woonkie
Woonkie
Adam
Las Vegas
24 went down to 12 speakers from the 18 on the 23 is to my understanding.
abcut973
Anthony
Denham Springs
I'm talking about the 4 buzzer sounds when I press the start/stop button.
That's telling you your seatbelt is unbuckled. It's kind of dumb because it's not clear at all that is what the noises mean.
I removed the noises with Forscan when I discovered someone had figured out how to do it.
