TSB 25-2124 Illuminated Powertrain Malfunction (Wrench) With DTC P2797
Mike G
N. AL, USA
2022-2025 F-150 Lightning (built on or before 19 Feb 25)
NA markets only.
Issue: Some of the vehicles listed in the model statement above may exhibit an illuminated powertrain malfunction (wrench) indicator with DTC P2797 stored in the SOBDMB and/or the SOBDMC. This may be due to the software in the SOBDMB and/or the SOBDMC.
Action: For vehicles that meet all of the criteria in the Issue and Model statements, follow the Service Procedure to reprogram the SOBDMB and SOBDMC to the latest software.
Note: this means the rest of the powertrain system modules (as available) would also get updated at the same time.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
Interesting. I would hope that unnecessary battery module replacements weren’t being done when it was actually just this.
Mike G
Mike G
N. AL, USA
No...those would throw BECM DTCs instead.
FANTIEPEI1
MARTIN
TRI STATE
2023 LIGHTNING LARIAT
Defender of all free things
well mine is at the dealer now because i have the wrench and powertrain malfunction and they called me to tell me i need a battery module replaced
Mike G
Mike G
N. AL, USA
Well okay...you get a wrench light for a lot of things. It would all depend on what the actual DTCs are once the system is scanned that determine the repair path. In the TSB I posted, it specifically says a wrench light with a very specific DTC.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
NA markets only.
Did this come with any new updates or is the fix in the versions that were online last Saturday (when mine were updated)?
Mike G
Mike G
N. AL, USA
Should have been the version you applied already. They always make the updates available in FDRS before they send out a TSB or SSM about it.
majorgearhead
Summerville, SC
2023 Ford Lightning Lariat ER
Computer Systems Engineer
Interesting. I noticed all of these module updates and performed them this weekend via FDRS. Note I have never had the wrench symbol. There was an ABS update that was tied into it as well.
FANTIEPEI1
MARTIN
TRI STATE
Well truck is back from dealer in record time. Module replaced everything seems to be back to functioning normal
Mike G
Mike G
N. AL, USA
So powertrain on a Lightning includes; PCM, ABS, BECM, GFM2, SOBDM, SOBDMB, and SOBDMC.
Sometimes they send out updates for one or two of these, and sometimes it's a full set.
Yammy5
cory
2022 Lightning Platinum and 2023 Mach-E Premium4X
Spill Research
Update on my repair saga....they have now replaced the heater, the heater wiring harness, the cooling pump and the DC-DC inverter. The Ohms had been reading 1.2 which is below spec but when then replaced the cooling pump there was a small improvement and once they replaced the DC-DC inverter the reading went to 1.61 which met the spec of 1.6. The truck is undergoing field tests (driving and L3 charging) before confirming it 'fixed'. Almost there....maybe.
