TNVolFan
RG
Kentucky
2023 F150 Lightning XLT Stanard Range
Do these work with heated seats?
Evlar77
Evlar77
Evan
Port St. Lucie, FL
2024 Ford Lightning Flash
They seem to. My wife used it on a trip this weekend and said they warmed the seat just fine. Probably takes a little longer to warm due to the added material.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
There was a pretty serious smoky fire last winter posted here involving seat covers in the back that had been left on for sustained time. The seat covers were used to protect the seats from dogs, so it was probably pretty thick. The point , these seats can get very hot, so you want covers that will not restrict the air too much.
https://www.f150lightningforum.com/...-fire-not-an-ev-fire.18385/page-4#post-369794
The manual includes the following:
HEATED SEAT PRECAUTIONS WARNING: Use caution when using the heated seat if you are unable to feel pain to your skin because of advanced age, chronic illness, diabetes, spinal cord injury, medication, alcohol use, exhaustion or other physical conditions. The heated seat could cause burns even at low temperatures, especially if used for long periods of time. Failure to follow this instruction could result in personal injury. WARNING: Do not poke sharp objects into the seat cushion or seat backrest. This could damage the heated seat element and cause it to overheat. Failure to follow this instruction could result in personal injury. WARNING: Do not place anything on the seat that blocks the heat, for example a seat cover or a cushion. This could cause the seat to overheat. Failure to follow this instruction could result in personal injury.
flyct
Jerry
South Florida
2024 Ford Lightning Platinum 2024 F-450 Platinum & 2-2023 Tesla Model Ys
Blissfully Retired
I had an issue with dog cover on the rear seat. The dogs hit the seat heater button and turned the heater on. The seat got Really Really scary hot. To eliminate an issue I removed fuse #48 in the picture attached to prevent inadvertent actuation of rear seat heaters.
Ford F-150 Lightning Great Seat Cover Option with Pics! IMG_2023
Pod
2023 AMB Lightning XLT SR
All right dude, pulled the trigger. Excited to get these
Pod
Got em. Install pretty simple. Drivers seat cover moves around a bit too much. Trying to figure out a way to keep it better in place. They really do look pretty good, have to admit.
Evlar77
Evlar77
Evan
Port St. Lucie, FL
Once I got the Pucks secured behind the seat and the front clips in place mine doesn't move at all. But I do have these over the cloth seats so they grip the original seats better.
A few weeks in and they still look and feel great! Glad you like them!
justincsfl
Justin
South Florida
2023 Ford Lightning XLT ER
I have a 2024 Flash trim. Love the truck but was a little bummed about the cloth seats. While they are well made I have pets and a kiddo and it won't be long before they get stained (despite two treatments of scotch guard).
In looking at options for seat covers (slide on) or seat covers replacements (more work) I settled on this set that looks a lot like the Lariat seats.
https://www.amazon.com/dp/B09VL423GP?psc=1&smid=A3VND82C9BC5CG&ref_=chk_typ_quicklook_titleToDp
Quality is there for the price ($250) and install was pretty easy, < 1 hour. I've been disappointed with seat covers before but these are definitely better than previous ones I've used. They are staying in place and at first glance you'd think they are original seats. They also add some added cushion and comfort to the seats. Will have to see how they wear over time.
Hey I’m considering this and checking in after 6+ months, how are they holding up? Would you buy them again?
Evlar77
Evlar77
Evan
Port St. Lucie, FL
They've been great for me! No tears, worn spots, etc. I think they actually look more OEM now as the covers have relaxed to better contour the seats.
We are an active family; they've been puked on, slobbered on, spilled on, and food crumbs everywhere. They clean up nice. I do have to occasionally tug the rear bench small cushion cover back strait every so often after the kiddos and dog have been pushing around on it.
Overall solid purchase and I now forget they weren't part of the car. I don't remember what the cloth seats under even look like lol. Just my experience... You may feel differently.
justincsfl
Justin
South Florida
Appreciate you taking the time to provide feedback. I shall make this purchase now 😃
SunPowered
Ben
2024 F-150 Lightning Flash
Ordering a set of these based (completely) on this recommendation. Had some poorly fitting but functionally protective seat covers on prior vehicles and happily, these look far better fitting and more custom. Also going into a (just arrived) new, cloth interior Flash. Thanks for posting.
22legit2quit
2024 Ford Lightning Flash ER
Purchased. They look spectacular. Price is fair too.
QUOTE="Evlar77, post: 438317, member: 19415"]
[/QUOTE]
SunPowered
Ben
Have installed the set cited in this thread and first impressions are, they fit great. Not at all difficult to install by following the product video. Unfamiliar person might not even realize they are seat covers. The stitching of them does nicely echo what appears on the Flash dashboard. Only minor nit is that the design of the center console cover does not allow it to do its flip over trick. It is a single cover that envelopes both halves of the console lid into a single block. Up to the user whether to use this cover or not, but a very minor knock. Overall very pleased with the fit and look. Thank you for the link.
indyaces
Vic
Ford Lightning Flash 2024 Midnight Blue
I assume these go over the old covers (we dont have to unzip the installed seat covers?), I have the same interior, is the light grey match pretty well with the truck interior, looks like the black of the new seat covers, is darker than the dark grey interior
Thanks for in advance, and for posting your review
justincsfl
Justin
South Florida
I ordered an all black set for my xlt lightning I should have them to me and installed by Sunday / Monday. I’ll share photos once completed.
