21st Century Truck
Martin
I think it's important to also factor in secondary costs of necessary periodic maintenance vs. just about zero maintenance when comparing towing with the Lightning vs. towing with an ICE vehicle. It's just like owning a Lightning vs. owning an ICE truck, without any towing.
The gasoline / diesel maintenance costs are A). recurrent, b). necessary and C). mileage-dependent.
rockfish
Rock
Shoreacres Texas
23 Lariat, Star white. ER Max tow.
aircraft mx.
Update on my Memorial day trailer pull / camping trip.
I left my house with 100 SOC . 330ish miles on the GOM . My transcend 240ml comes in 6400 pounds dry and 7500 GVWR. i always like to pull it dry as we try to stuff as much food and stuff in the camper and coolers with beer (very essential ) into the bed. 62 miles one way light headwind from the south and i ended up .09 MPK both directions and 45 miles left in the tank. I forgot to document it as i was super excited to get everything set up and get some frosty beverages down.
I would like to add that even though it said 330 ish miles as soon as i dialed the camper in the GOM went down to around 155 miles, concerning but i wasn't too worried i knew i could make it there i was just worried about the charging. Being a state park with 50 and 30 amp service poles, i was able to use the ford mobile charger on the 50 amp was back up to 90% by midnight, so no issues with that. all in all was a great 4 days although we did run out of beer. ..... a couple of times ....
Ford F-150 Lightning Towing test for upcoming travel season lighting camp 2025
B177y
B177y
Oly Pen, WA
2024 Pro ER Max Tow
....62 miles one way light headwind from the south and i ended up .09 MPK both directions ....
I assume you mean 0.9 MPK, not .09? I'd be a little concerned with .09.
rockfish
Rock
Shoreacres Texas
aircraft mx.
typo yes you are correct 0.9 MPK about 65 to 70 mph. also i could not get the blue cruise to activate with the trailer. Is that a safety feature that others have found? or is it i just have the crappiest version of blue cruise. ? Just went in and checked on that. Yes it is a safety feature and you cannot tow with blue cruise. , and yes B177y you can use the the adaptive cruise , which i was able to use , probably better than taking your hands off the wheel with all that weight.....
B177y
B177y
Oly Pen, WA
2024 Pro ER Max Tow
I don't have Bluecruise, but from what I have read on here it does not activate when you have a trailer connected. I guess that's a safety feature?
EDIT:
When I towed my trailer to Forks and back, I was able to use my adaptive cruise and lane keeping... "Hands on" Bluecruise if you will.
I recently installed a Comma.ai and from what I have read that will allow the hands-free driving even with a trailer. I will likely still be more comfortable hands-on while towing though.
MidAtlanticLightningClub
F-150 Lightning Lariat ER
The 65 to 70 mph is the critical part here. With our trailer (24.5' NoBoundaries 19.8), we get:
0.94 mpk at 60 mph
1.09 mpk at 55 mph
1.26 mpk at 50 mph
BlueCruise Hands Free will not operate when pulling a trailer.
Adaptive Cruise Control with Lane Centering (formerly known as Hands-on BlueCruise) works fine when trailering.
spectacle
Peter
2024 Flash ER, 2022 Ioniq 5 SE, 2018 Leaf SV
Many thanks to all here and other posted about pulling weight. With your learning and ABRP (with paid subscription), I felt very confident in my first test with my ‘24 Flash ER. I drove from NW OR to San Jose to load and haul my sister’s belongings to OR. Bed was packed as tight as possible, and 6x12 U-Haul trailer fully loaded. I estimate at least 4,000 lbs GVW, maybe 500 in the bed. Estimated conservatively 0.9 for ABRP planning, ended up getting avg 1.5 over 745 miles. Just stuck it on 55 and left it there, drove the 101 rather than I5 (liking interstate highways less and less). Charging at various CCS plus a few Teslas was excellent.
Ford F-150 Lightning Towing test for upcoming travel season IMG_1353
Ford F-150 Lightning Towing test for upcoming travel season IMG_1351
Ford F-150 Lightning Towing test for upcoming travel season IMG_1350
