tearitupsports
- First Name
- Russell
- Jun 1, 2024
- Houston, TX
- 2023 F-150 Lightning Lariat ER
- Occupation
- Industrial Automation & Controls
Today I had a successful test of using the generator input of my PointGuard Home battery system with the Lightnings Pro Power Onboard (7.2 kW 240V outlet).
For reference I have been testing a couple systems. I have the original Ford / Sunrun HIS (which worked for me), and have switched to the PointGuard Home system.
PointGuard (Sigenergy elsewhere in the world) is a hybrid battery/solar inverter. They also have an automatic transfer switch called the load hub, which has some metered input/output loads. One of those is a dedicated generator input rated to up to 80A breaker.
The battery system is one of the modular stackable kinds, so I have 2 batteries for 16 kWh total storage. I have this much because I utilize time of use rates on a day to day basis, and save a lot on energy cost by having extra battery. The minimum setup if you chose this route would be 5 kWh. I also backup nearly my whole home including my 5 ton AC. I do have a critical loads panel, but it is a full 200A 42 circuit panel and has everything except the dryer, oven and EV charger.
One of the main features of the PointGuard system over many other is the 0ms fail over. None of the powered loads turn off when going to an off-grid condition. In fact if I didn't get a message pop up, there have been a couple of times I would have never known the power was out.
For the Lightning I have decided to try the easiest option of integrating the truck with the generator input (which only is active in off-grid scenario). I have wired up just a 30A generator inlet to the outside wall of my garage. I put it in a spot where my cord will reach with the truck parked insider or outside the garage. I also have it in a place where I could use a small portable generator if I wanted to as well. I used #10 wire, so 30A is my max, and I will be making sure to really only use 24A max normally. I have a 30A breaker in the PointGuard load hub.
One nice aspect of this system is that I can set the amount of power I want to draw from the truck. In my test today I set the generator rating to 5kW in the pointguard app. It will power as much of the load it can using the generator, and the rest it will pull from the battery. If my load is low, then it will maintain the load and charge the home battery with the excess, still at a total of the rated amount (5kW for me today). As you can see in the pictures below it maintains that 5kW perfectly.
The second aspect is that the truck does not have to be always plugged in. Even when disconnecting the truck by turning off the pro power, there is no break in the power to the house. I can charge up the home battery and then disconnect and go drive the truck if needed. This is why (to me) it is worth spending the extra money on a system like this. If the power outage was localized, I could even go charge the truck elsewhere and come back without leaving the family in the dark.
PointGuard support is top notch. I actually had a small issue with the generator input, and reached out to them via email. They actually went ahead to give me a call and explain how it all works. It turns out that I actually had a nicked wire causing a short, and was not an issue with any of the system itself, which was much easier to find with them walking me through how the system worked.
In the future I may try to get my HIS Delta inverter working with the PointGuard. I am not sure if that is possible. The other main feature of PointGuard is they have a V2X charger that stacks in with the battery and can do all the bi-directional energy right through the charge cable. Unfortunately I have too much money tied up in old existing equipment to give that a try right now, especially with this generator input working great.
