Noisy Air Conditioner (or Outside Fan)
strmwzrd
Nebo, NC
F-150 Lightning Lariat
I saw a few mentions about the a/c system being noisy but I think mine, 2023 Lariat ER, is getting too loud. I've been getting intermittent cooling issues lately too so I may be listening too hard. Attached are some sound bites.
EFG
Ed
Lightning, chevy bolt, bmw 1200rt, 23 ford t-bucke
software developer
My neighbor has said that my '23 SR Lightning is louder just sitting in the driveway with the A/C on than his ICE F-150. I have noticed when it gets above 90 or so ambient that it is pretty loud. It has always been that way.
htobin
Howard
Ovalo TX
F150 Lightning 2023 Lariat
Retired surgeon & jet aircraft pilot, Active rancher
Mine is also real noisy if you turn the fan up to its maximum. Fortunately, the cooling is adequate without setting it that high.
K6CCC
Glendora, Calif.
Yep. Surprising how much noise it makes.
HammoJ
2025 F-150 Lightning Flash
Any chance it's the noise generator that operates when DRIVE is engaged and moving at lower speeds?
K6CCC
Glendora, Calif.
Definitely not in my case. I notice it when walking up to the truck with Climate Control turned on.
Mine (2023 Pro) doesn't make that noise, at least not that I can hear from inside the cab, but mine does make a very low volume high-pitched sound as if it is communicating via Morse code with the mother ship when the fan is going on low, when the fan is higher the air blowing noise drowns it out.
Not sure I have a recorder that could pick it up adequately but if I think of it next time I am driving with AC one I might try.
I had a one-time event on a super hot (over 100F) day where there was no cool air on MAX COOL and there was an awful smell of coolant, probably a gasket/seal leak due to high pressure at a compressor because of the high temperatures (I was parked for 20+ minute on asphalt in direct sun with the truck off), but after the truck was parked in the shade for an hour or so everything was back to working fine with no coolant smell.
There have been reports of coolant leaks from the reservoirs so maybe check that?
There have also been reports of a failed valve in the rather complex network of cooling pipes in the trucks.
Excessive noise from a compressor can be a sign something is wrong (bearing seal or other compressor components - not sure what the Lightning compressor(s) are made of) so if it sounds really bad that could be a sign?
Good luck.
ChrisInVegas
Las Vegas, NV
I live in Las Vegas where it gets hot in the summer. When I was interested in buying a Lightning, I test drove several in June when the temp was already over 100. Every time the sales rep would pull a truck around for me to drive I noticed the fans were really loud. Mine is too.... It's normal. You have big fans running hard to cool the battery. That takes a lot of air.
The sound isn't loud in the cabin for me, but when I turn on the HVAC before walking out to my truck, it is pretty loud.
Now... if you truck isn't cooling or if your battery/motor temp is going red... that's a problem.
Loud is relative anyway.
So is annoying.
I find some loud things fine to listen too, like when I went to a Mahavishnu Orchestra concert in the 1970's - loudest music I had ever heard/felt, but clean and crisp and emotionally moving.
While I find other things less loud things very annoying to hear, like the darn refrigerator's urgent "ding ding ding" when I'm taking too long (in it's opinion) to find something to eat in there.
The Lightning AC fan noise - I don't hear it inside the cab so not loud or annoying, if I did hear it, I might change my mind.
strmwzrd
strmwzrd
Nebo, NC
So is annoying.
I'm not as concerned with the noise (I don't hear it in the cab to speak of) unless it's associated with my way-to-warm A/C. We'll see what the dealership says on Thursday. More to follow...
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
Have you checked your cabin air filter? I had a new filter that was too restrictive and the fan got noisy, change back to the standard filter and it stopped being noisy.
strmwzrd
strmwzrd
Nebo, NC
Just today I wondered about the filter since the dealership didn't change it at 20K, but I decided since I can not get good cooling with recirculate on I figure the filter wasn't an issue. I'll check in a few minutes. Thanks.
