Jackdforme
The long story short is this I have a 2025 flash. I’ve been trying to get the rain sensor working and while I wait for a harness, I’ve been trying to figure out if software is the reason that 12 V is not being supplied to the factory OEM three pin plug.
So I went to Reddit and someone suggested a ChatGPT answer which made a suggestion about asking the BCM to turn on the 12 V trigger for the rain sensor using 726-12-01. I changed the last digit of the first byte to a 1 from 0 and wrote that.
When I reset for that change, I got two errors precollision system not available and service advance track.
I performed the BCM reset and waited a little bit and restarted a few times same results.
I backed out the change to a zero and performed all of the same steps and yet I continue to get the same result and error.
Can any of you provide some wisdom here on how I can alleviate this could it be purely coincidence because I was in my driveway in a rainy environment in the dark when I started it?
I guess I’ll know tomorrow when I drive it, but if any of you have any insights, please let me know
