Edmunds 3 year Lightning review
NeighborGeek
Steve
2025 F150 Lightning Flash
You should have three memory buttons on the driver door. Set one to your normal, set two for a spouse if needed, and set 3 to the same as 1, but turn off 1PD and Auto Hold before you save the profile. Can then just hit 3 when you want them off, no menus.
Nope, I could only afford a Flash. No fancy memory for me.
watts/up
23 Pro SR
If it makes you feel any better I’m in a Pro without even carpet. But @Vulnox that solution is brilliant.
Vulnox
Livonia, MI
Ah darn. I thought on the Lightning the memory buttons are on everything XLT and up. My bad.
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
For all those frustrated about channels that buy EVs, drive them for a short while, then sell them, there is a YT channel out there that doesn’t do that.
A channel thats been covering the industry for (checks) 15 years.
Just saying ;)
Oh, and also, for that channel, the vehicles aren’t write offs. Paid for using loans like normal, treated as family assets.
Youtube.com/transportevolved
Traconesu
Patrick
Quad cities, Illinois
Ford lightning platinum
Just saying ;)
I subscribe to that channel. I enjoy most of her content. One I definitely disagreed with was getting the sunrun home integration system. Way too expensive to purchase and even though she had qualified installers she's had nothing but problems with her system. Aside from automatically switching in the lightning when a power outage occurs (which as far as I know still doesn't work on her system) I installed a manual transfer switch that I use to power my home from my lightning, my Ecoflow Delta pro 3, or a generator depending on what device I want to use. All that at a fraction of the cost of the sunrun home integration system. I've also discovered that sunrun never did a very good job designing the Ford 80 amp charger and why it trips out charging and then starts back up. There's no fan so after I installed a small 240 volt AC cooling fan that solved that problem.
Ford F-150 Lightning Edmunds 3 year Lightning review 20250703_070921
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
Have been a follower and a patreon supporter for years now of that very channel!
