Ishkatan
- First Name
- Adam
- Mar 25, 2024
- Monrovia, Md
- 2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
- Occupation
- Old
I experienced surging (back and forth pulsing) in my 2023 Lightning Lariat ER while towed a Harbor Freight 1750 lb rated trailer with two 10 Ft logs about 0-12 inches in diameter when going up 2-3 degree hills.
Minor info note: The phone app is showing me milage estimates based on the trailer still being connected (192miles at 80% vs 246 normally). I plugged the truck in (Pro charger at 80 amps) with the trailer connected but now the trailer is disconnected. I have not started the truck since plugging in with the trailer connected.
- I estimate each log was about 300+ lbs. so total loaded trailer weight was likely under 1000 lbs.
- The hitch was tight and there was very little play and no banging at stop lights or accelerating.
- Trailer tires were at 70-75 PSI - below the recommended 80 psi for a fully loaded (1750 lbs) trailer but did not show much sidewall flex.
- Trailer tongue weight was at the limit of what I could lift from a vertical cement block to the hitch ball. I am told I am strong and I estimate 100 lbs.
- Trailer was at a slight upward angle and a 1-2 Inch drop would make it level. I have used this same hitch setup on an Avalanche 1500 with no surging but a different load.
- The trailer tracked perfectly with no sway on straight sections and on turns. I had the trailer camera turned on for most of the trip,
- This trailer does not have brakes - 4 pin connector.
- The surging only happened going up hills. 1-3 degrees per the dash angle indicator, which seems to be reacting slowly.
- Flat and down hill sections had no surging. One road section was new asphalt so road was very smooth.
- *** The surging was much worse with Adaptive Cruise Control. Much less noticeable but still there with adaptive cruise controll turned off.
- I do NOT use one pedal driving.
- 2.1 m/K electric draw for the 28 mile trip.
- I had the truck set for towing. The Harbor Freight trailer settings gave a range estimate of 104 miles but changed to 164 after a short while towing. My conclusion is that I gain battery range if I tow with a lightning.
- Speed varied 40-55 mph, mostly under 50 mph.
- Truck is stock with 16,400 miles on it. Tires were rotated but not balanced at 10k miles.
