2025 Lariat Trim rear drivers side top seat fold down
jeep2liberty
Curtis
2025 F150 Lightning Lariot
My first post, and hope this isn't duplicated.
I needed access behind the drivers side rear seat for a ham radio install.
Once you raise the bottom seat up, the top part of the seat moves away from the rear cab. Because of this movement,you can then see the latch located about 10 inches from the door seal, inboard and about 6 inches down from the top of the seat.
I'll attempt to upload a photo.
Hope this helps someone, somewhere.
Joe Dablock
Stewartstown Pa. 17363
I tied a string on the inside of the part you circled and tied the other end of the string to the headrest. So all I have to do is pull the string to release the back.
jeep2liberty
jeep2liberty
Curtis
At least on the 25 Lariot Trim, the pin just pushed downward.
Your actual "gas mileage" may vary depending on perhaps trim package.
Ford F-150 Lightning 2025 Lariat Trim rear drivers side top seat fold down 20250808_191834
jeep2liberty
jeep2liberty
Curtis
I like it! Simple and straight forward.
MaintGrl
Marsha
El Sobrante, Ca
rembrant
Miles
17600 Baltar street
f150 lightning
painter
Is this available on a 23 XLT? I’m curious if it’s only on the lariat model , I would love to use the behind the seat storage.
cwstnsko
Mesa, AZ
2023 F150 Lightning Lariat ER
I the XLT and lower trims, there might even be usable space back there. On Lariat and above, the space is almost completely filled by audio components.
F150Redux
Daniel
2025 F-150 Lightning Lariat
Computer Geek
If you want to be fancy, there's a product for this...
I bought this to try out in my 2025 Lightning Lariat. Install was easy once I got the seat down initially, but no matter what I did I couldn't get it to latch correctly once it was installed.
I wasn't willing to do the melt/cut suggestions from the FAQ and others, so I just returned it.
As noted, with the audio stuff back there I probably won't access it much. If I decide to swap out the sub/amp then it's easy enough to release with a small closed ended wrench (once you know the right spot).
Mike G
N. AL, USA
This applies to all trim levels.
....and I've been using the same one on all my F-150s (5 so far including two Raptors). I just keep moving it from truck to truck when I trade them in. :) It's been very handy at times.
For those who like videos this link may help. If you're having problems getting the seat back to latch after you've installed the strap assembly, pay attention to the video starting at the 9:50 minute mark.
watts/up
23 Pro SR
Mine won't relatch when swinging just the back up but if I swing the seat and back up together it latches fine.
Adventureboy
If you unlatch the seat and fold it down, you may need to move the floating latch bar to align with the latch before it will latch back again. It can be a bit fidgety to get it in the right place since it is hard to see.
It is easiest method is if you have the seat in exactly the same position as when you unlatched it (usually up because that makes it easier to access the latch.). If you have the seat down, you need to move the latch bar to line up.
