Is your truck making new dings and gong sounds?
GunRack
Peter
Seattle, WA
22' Lighting XLT
I hadn't driven the truck a few weeks but tonight its making different dings and gong sounds for parking sensors and general tones. Did I miss this in an earlier update? They aren't significantly different, but different. Kinda preferred the old sounds.
Kansan
Wayne
2024 Flash
Civil Engineer
Probably a low state of charge on your 12v battery. The sounds are different when the battery is low.
GunRack
GunRack
Peter
Seattle, WA
22' Lighting XLT
Didn't know that was a sign, thank you! I'll try a battery charger on the 12v battery
Rayden
'23 Lightning Lariat ER
Yeah, I didn't know that either.
BennyTheBeaver
The sound is coming from your Instrument Cluster instead of the Speakers. A couple various things, including low battery can change this. It usually goes back to speakers eventually (at least it does for me) on the next drive.
There is actually a setting you can change in Forscan to force it to remain with the IPC's speaker.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
My truck just started doing the same thing. I thought I remembered it might have something to do with the 12 volt battery. Wonder if the Walkaway Locks update is taxing the 12 volt battery a bit more than it was previously.
Alan168
Alan
Massachusetts
2022 Lightning Platinum, Rapid Red Metallic
I just had my ‘22 Platinum truck in for 30k maintenance. The dealer updated the software in a bunch of modules while it was there. I noticed the tone changes immediately after picking up the truck after the service. No other work was done other than tire rotation.
