- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
I get what you are saying.I assumed he was referencing the GM charger since the plug type was CHAdeMO, I don't know what they actually use, I just know it's not what's in the lightning.
But maybe the 'bug' is also how the Ford/Siemens/SunRun/Delta system does it, eh?
Do we really know there is any danger?
I would hope the SigEnergy system is UL (or some other) certified.
Yes the standard may still be under development, but I imagine the makers of the V2X equipment will adhere to it and modify existing systems if needed to do so.
The IEEE published a V2X communications standard a long while back:
The IEEE publishes 802.11 a vehicle-to-everything (V2X) standard based on WLAN. The standard also supports V2I communications between vehicles and highway infrastructure and between vehicles (V2V). It is presented as an amendment to the Wi-Fi standard to cover vehicular communications as part of Intelligent Transportation Systems (ITS) and operates in the licensed ITS band of 5.9 GHz, which is allocated by the FCC in 1999 and the European Commission in 2008. Intended solely for inter-vehicle, infrastructure communications and priority transport safety applications, it is the basis for Dedicated Short-Range Communications (DSRC). The data volume of DSRC is low and intended for road safety, traffic efficiency, energy savings and surveillance. With only a small number of small pilots having used the spectrum, the FCC re-assigned it in November, 2020, citing lack of use. It did leave some spectrum (30 MHz) available for cellular V2X, a different standard based on LTE.
NEMA recently released their own guidance Feb 2025:
The National Electrical Manufacturers Association (NEMA) this week introduced a unified framework for “vehicle-to-grid” (V2G) and “vehicle-to-home” (V2H) technology, allowing EVs to discharge electricity as well as store it. The standard ends years of fragmented approaches and competing systems that have slowed commercial rollout.
Automakers and utilities have already begun to test the concept. Toyota has partnered with San Diego Gas & Electric on a pilot programme using its all-electric bZ4X model as a grid-connected energy source. Such real-world trials are intended to show how parked vehicles can support power networks during demand peaks or supply homes during blackouts.
“This standard is a turning point,” said one utility executive involved in early-stage projects. “It makes EVs as vital to our energy future as they are to our roads.”
Analysts say the move could reshape electricity markets by adding millions of potential microstorage units to national energy systems. The technology may also allow households to sell power back to utilities or lower bills by using stored energy during high-tariff periods.
However, not all carmakers have committed to the NEMA framework, and questions remain about its impact on battery longevity. Industry executives have said that data from pilot schemes will be key to determining how much regular bidirectional use shortens battery life.
Despite the uncertainties, momentum is building. US policymakers have linked broader EV adoption to national energy resilience goals, while utilities view distributed storage as a low-cost buffer against grid instability.
With the new standard now in place, industry observers expect a wave of new products and partnerships within the next two years. If successful, the shift could mean that the electric vehicles parked in driveways across America will soon do more than wait for their next trip; they will help power the grid itself.
https://www.vehicle-grid-summit.com...le-to-grid” (V2G) and “vehicle-to-home” (V2H)
I haven't read it yet but it is a communication standard:
The Connected Vehicle Infrastructure – Roadside Equipment Standard (NEMA TS 40010-2024) is available in NEMA’s Standard Store.
Anyway, there is a lot we don;t know the details about.
But the voltage and current levels should not be a worry.
Fail safe protections should/would be built in to any decent V2X system.
More to learn though.
