Massachusetts - Vehicle to X Program
tearitupsports
Russell
Houston, TX
Our deployment is using the Ford Home Integration System (HIS). Is that what you have?
It sounds like the HIS is the limiting factor.
The Delta Ex_BDI is the Ford inverter. There is no limitation in the HIS. Sunrun is just giving you the wrong info.
Ford F-150 Lightning Massachusetts - Vehicle to X Program IMG_2653
Ford F-150 Lightning Massachusetts - Vehicle to X Program IMG_2654
JvdMaat
W. Mass
We (people with solar panels) had a meeting with the program yesterday. The big takeaways were:
- There's no net metering. AT ALL (ie, you will NOT be paid for ANY electricity you feed to the grid.)
- There is no TOU rates (unless your current provider already has those for you).
- The only compensation for feeding to the grid is at the end of the season at a rate of $275 * (average kW sent to grid over the 30-60 events). So in the case of our Lightnings, this maxes out at 275*9.6=$2,640 for the 2026 season. But if you miss an event (you were out), or joined late (event started at 5, and you didn't plug in till 6), those lower your average by getting 0 for those times. (Discharge rates get reported in 15 minute intervals)
For solar people, there's no more net metering on any solar we feed to the grid. (The technical reason behind this is that net metering is for renewable energy. And the minute you add the truck, they can't certify what generated the electricity fed to the grid (could be from a public charger.))
So you could be "earning" up to $2640 per season. But you do not get paid for the electricity fed to the grid for V2G (At an average of 45 events, at 3 hours each, that's 45*3h*9.6kW=1296kWh (and we're all paying over 30 cents, so that's anywhere from $388-$453). (And yes, that's a cost, not a loss, as after the discharge event, we need to recharge the truck back up with 1296kWh from the grid).
So the yearly profit is a potential of around $2000. Give or take. (The more events, the less profitable, as it measures in kW, not kWh). But still a good deal for us getting the equipment for free. Future participants needing to pay for the gear will have to figure out their break even point. That could potentially be 10 years down the line
Having said all that, it isn't completely bleak for solar users since we're Lightning owners, and Ford partners with Sunrun (I know many don't agree with this, but the Kia and Nissan chargers do not support this, so we're "lucky"). Sunrun can provide (as @tearitupsports showed) a system that supports the EV, batteries, and solar in their microgrid controller. So I'm working on getting a quote for batteries as part of this.
And the goal will be to charge the batteries from the solar, and drain the batteries as much as possible overnight to be able to receive solar power again the next day. (Since any solar fed to the grid is "wasted" (it's used by others (so it doesn't actually go to waste), but not compensated to us)). If I can retain all my solar production internally, that'll be similar to net metering.
And then the new batteries can separately apply for ConnectedSolutions (as some of you already have batteries that do this), and we still get some benefit from our solar panels. (At the same $275 per kW discharge rate to the grid. With the advantage they're always online, so no missed events). And EV and batteries will be discharging simultaneously during the events.
When you stop net metering solar, you do get paid for having solar feed to the grid, but it sounds like it's a monthly flat fee of $2.60 per kW (system size). So while not nothing, it doesn't cover the potential electricity fed to the grid.
Hope that answers a bunch of questions.
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
With the lowest amount of energy possible, I hate this. Net metering is 100% possible with the truck in the equation, it's just the utilities not wanting to implement the hardware.
Put the charger on it's own utility meter and treat it as a quasi new-service. Compare the interval values against each other to know if it's charging with excess PV and when it's discharging. Or just look at when it's discharging and base incentives on that.
It's 100% possible. The hardware exists, but the political will and forward thinking does not.
JvdMaat
W. Mass
It's not a hardware issue. It's a compliance issue.
They cannot do net metering on non-renewable energy.
So solar net metering, no problem, it's renewable, generated right inside your home.
But net metering on the EV is a problem. If you charged up at work, that power may only be 80% renewable, and thus not qualify. (Or if you charged up out of state, it may be even less renewable, depending on local state rules)
And even if you make sure to only charge up at 100% renewable sources, there is no way to certify that. It's just your word.
(Even charging up at home, unless you have a 100% renewable provider, basic Eversource electric is only 63% renewable, so not eligible for net metering)
sanj
Sanjay
Massachusetts
2023 ER
Hey all. Newcomer to the forum, but this appears to be the best place for the MA V2X conversation.
Here’s my current analysis, based on this thread and some side chats.
The programs isn’t a great deal from the standpoint of maximizing local energy usage. The inability to charge the truck with excess solar and feed the house from the truck (except in outages) is lame. The removal of net metering is also lame.
But helping the grid is appealing. And the money probably works out.
So I’ll probably do it.
The big open question is whether the gear that's installed can be made (after the trial) to do what I really want.
And what I really want is:
1. Charge the truck with excess solar during the day.
2. If the truck is full, send excess solar back to the grid (net metering)
3. Use the energy in the truck at night, or when I'm drawing more than the solar can service.
It sounds, based on @tearitupsports's analysis that this can be done.
But is there any information about whether it can be done with the equipment being installed? My concrn is that it'll have locked-down firmware that isn't able to be upgraded.
JvdMaat
W. Mass
That's a good question. They already denied me. For this all to work, the solar needs to be connected to their inverter. And they will not convert an existing system. So my solar will be stand alone and not connected. The only option after this program is to see if I can rig the solar panels into their inverter. (Right now I have 2 SolarEdge inverters for 6 and 4 kW each)
I'll be taking to my wife this weekend to decide if we want to continue and lose net metering, or if we should bow out and give someone else a chance.
(The solar will still be connected, and power the house during the day, which would also power the truck if connected. But there'll be no smarts. And no storing power into a battery to discharge at night)
JvdMaat
W. Mass
What do you mean that they denied you?
They said they could not integrate my existing solar into the HIS system.
So it would be just like grid energy to the system.
Can't specifically charge batteries off the solar (and not grid) only.
frost22
2022 F150 Lightning Lariat SR (510a)
I just got an email that I was selected. Has anyone had the hardware installed? What was your experience like? They're going to put in an 80A Ford Charge Station Pro and a Sunrun HIS
f150lex
Jeffrey
f150 Lightning
So far the experience has been fine, though a bit confusing.
Sunrun sent electricians to install the backup system. There were a few hiccups (some components needed to be installed outside due to space limitations, holes were drilled through walls as a result, clean-up of debris was distinctly sub-par leaving a lot of dust and vacuuming to be done by me), but the equipment was free. It seems to work.
F150Redux
Daniel
2025 F-150 Lightning Lariat
Computer Geek
Got an email this morning that the Massachusetts Vehicle to Everything (V2X) program is accepting new applications again:
https://www.masscec.com/masscec-foc...structure/vehicle-to-everything-demonstration
I signed up. It said decisions will be made in March.
There was a question asking about recalls; it wouldn't let you continue without checking a box that said there are no recalls. My truck, like many of us here, has the open IPM (parking brake) recall. I figure that has nothing to do with the charging infrastructure, so I just clicked the button and completed the rest of the application.
NWilson
Western MA
2023 Lightning Lariat ER Star White, 1974 AMC Javelin AMX, 1968 IHC Scout 800
Solar
I had put my name on the wait list for the program in the fall because I got my Lightning soon after they closed the first round of applications.
I got the email in February saying they were opening up a second round of applications.
I have solar and saw the info about having to give up net metering in order to participate, and I had pretty much decided not to apply because of that. Yesterday, I decided to apply and see what they say if they selected me for the program. I started the application and when I got to the question asking if I have solar, I said yes. At that point, the application ended and said something to the effect of thanks for your interest but we're not taking people with solar at all.
It seems obvious that they rolled out the program without even considering the net metering issue and when it came up, it caused them a big problem so now they don't even want to deal with it and offer people the choice of opting out of net metering. Just a hard no if you have solar.
C6Bill
2025 F-!50 Lightning 1970 Olds 442
I applied when they reopened it in February, I haven't heard back from them so I assume I didn't get selected. But March isn't over yet so maybe I still have a chance.
F150Redux
Daniel
Computer Geek
I haven't heard anything either. I feel like everything government related they are just behind schedule. And, like you said, March isn't over yet.
frost22
I'm still waiting for a site walk. They told me mid-April.
