100+kWh energy after full charge on SR
msadan
Dan
Lafayette IN
2023 F-150 Lightning Pro, 2025 Tesla Model 3, 2010 Tesla Roadster
Pinball repair
I've been tracking the energy value shown after a charge to 100% for about a year and a half now. It's always been between 93.5 - 97.1 kWh (SR battery pack), with lower values corresponding to lower temperatures and higher values with higher temps. This is the first time I've ever seen it exceed the pack's rated usable capacity (98 kWh). With the battery's SOH at 98% I would have expected it to max out at around 96 kWh. Temperature was around 70 degrees, so pretty much ideal conditions. I realize that these values are all just estimates, but I thought it was interesting.
Ford F-150 Lightning 100+kWh energy after full charge on SR IMG_0860
On the Road with Ralph
Ralph
Mojave Desert, California
2023 Ford Lightning Pro
Real estate/biz consultant
You do understand that the actual size of the battery pack is larger than its usable capacity, right? There is a buffer built-in, both at the top and bottom of the range, to help preserve battery life.
msadan
msadan
Dan
Lafayette IN
Pinball repair
I do, that's why I referenced "rated usable capacity" in my original post. My point was that I found it interesting that the truck seemed to be using more than 100% of the battery's usable capacity, and that I had not seen that behavior before.
If the truck is in fact charging the pack to more than 100% of its usable capacity, that would mean that it's using part of that buffer, which would seem to defeat the purpose of the buffer.
Ralph
There has been some speculation the BMS is programmed to incrementally release part of the buffer as the battery ages to preserve range. I don’t think Ford has ever confirmed that theory, however.
Kev12345
Ram 1500
makes total sense to avoid battery warranty claims. full access to battery after 8 years maybe?
I'd rather keep the buffer as it is. Range is fine, loss of capacity is so low that it really isn't a problem. Plus, I like knowing that I have that buffer every time I charge to 100%. It's just safer with this chemistry.
