bc1
- Oct 25, 2025
- McPherson, KS
- 2025 Ford f150 Lightning Flash
Hello guys. 2025 Flash. The frunk and cab power outlets work just fine. I went to use pro power for the first time yesterday and it didn't work in the bed. Got all the other settings figured and reserve on manual down to about zero. Checked and found the bed plugins (orange wire hanging from the box attached to the bed) were just hanging and possibly left that way after having the bed liner sprayed.
The main plug plugged in just fine like it is supposed.
However the communication plug with 4 small wires only goes in so far. Figured out that the white male and female connector parts stick out enough that the entire assembly won't slide in until the holding latch on top engages. However it does connect together far enough for the 4 flat pins inside the plug attached to the bumper to slide into the other plug.
When I try to turn on the bed power on the sync screen by touching the bed, it lights up for a momentarily and I get a message about dealer service required.
Only thing I haven't tried so far is to disconnect the battery ground for 5 minutes to reset the system.
If the plug ends up working I will have to tape it to hold it together.
Any ideas? Thanks.
Any ideas? Thanks.
