Auto climate control inop after 25C69 (SOLVED!)
KHines
Kevin
Delaware
Had the truck in for the update and it seems like the auto climate control just isn’t doing its thing ever since. I’m getting cold air out of the vents so I know the hardware is working, but I have never had to use Max A/C or even bump temp down below 74 to keep the cabin cool in the previous 32k miles.
Anyone know of a calibration or reset procedure?
Thanks all - stay cool (see what I did there?)
GoodSam
Good
occupying space
Hope this is not due to a malfunctioning coolant diverter valve that others have reported, usually after hearing a clicking sound. What is your year? Do you have the heat pump?
I have never been happy with the low air flow out of the side vents. I usually keep in Auto with 3 lights on for the fan speed, but have to adjust the temperature a few degrees up or down depending on outside temperatures.
Putting ceramic tinting on the side and back windows has helped quite a bit for keeping me from feeling the sun burning through. Highly recommended. Not sure about doing the windshield as I see some color distortion thru the side windows.
KHines
KHines
Kevin
Delaware
Nope, I’ve got a ‘23 and like I said, it does blow cold just doesn’t regulate itself automatically, which means the hardware is good but the control logic is off.
Windshield tint is only for Floridians, Texans, Arizonians and criminals 😝
KHines
KHines
Kevin
Delaware
SOLVED!
Around the same time I had the truck in for the software update recall, I had also replaced the cabin air filter. Naturally, I bought what seemed like the best filtration available. Turns out this filter is too restrictive for the auto control to work properly, verified by a long drive last night in 95 degree temps with my normal setting of 74 degrees, fan speed max set on two segments. Failed to adequately cool until I removed the filter then it was almost too cold running without filter. This is the one I bought that I’ll now be replacing.
Ford F-150 Lightning Auto climate control inop after 25C69 (SOLVED!) IMG_5078
WildBlue
Somewhere
2024 F150 Lightning Flash
As an alternative that isn't as restrictive, but still filters well: Motorcraft FPP92. I used the filter above and while it works very well, it is too restrictive as the OP found out. The FPP92 (I got mine from Rockauto) is a little bit more restrictive than stock, but less than the one above.
Here's a Ford.com link.
GoodSam
Good
occupying space
ChatGPT says:
What you observed is very plausible from an HVAC engineering perspective. The climate control system itself probably wasn't "broken"—it was operating with airflow conditions outside what it was designed for.
Here's what's happening.
1. Automotive HVAC systems are designed for a specific airflow range
The blower motor, evaporator core, heater core, ducts, and control algorithms are all calibrated assuming a cabin air filter with a certain pressure drop.
Every filter creates resistance, but OEM filters are typically designed to balance:
Dust removal
Airflow
Noise
Blower efficiency
A true HEPA filter is very different.
HEPA filters remove at least 99.97% of 0.3-micron particles. Achieving that level of filtration requires very dense filter media, which dramatically increases resistance unless the filter has much more surface area (as home HVAC HEPA systems do).
Your truck's filter compartment doesn't have room for a much larger filter, so airflow drops significantly.
2. The blower fan doesn't move a fixed amount of air
People often think:
> Fan speed = airflow
Not true.
The blower produces pressure.
The actual airflow depends on system resistance.
Think of blowing through:
an empty paper towel tube
the same tube packed with cotton
Your lungs are working the same, but much less air comes out.
The HVAC blower experiences the same thing.
3. Auto climate control expects a certain airflow
The Lightning's automatic climate system uses inputs such as:
Cabin temperature sensor
Outside temperature
Sunload sensor
Evaporator temperature
Coolant temperature
Desired cabin temperature
It then estimates how much cooling power it needs.
Cooling power is approximately:
Cooling = Airflow × Temperature difference
If airflow drops 30–50%, cooling capacity drops by roughly the same amount.
The evaporator may become extremely cold, but not enough cabin air passes across it to cool the occupants.
4. The cabin temperature changes too slowly
Suppose:
Cabin: 95°F. Target: 74°F
The computer expects:
> Fan on medium = 300 CFM
Instead it gets:
> Fan on medium = 170 CFM
The cabin sensor sees:
"Why isn't the temperature dropping?"
It may respond by:
opening the blend door fully cold
increasing compressor output
increasing blower speed
But eventually the blower reaches its programmed maximum.
No additional airflow is possible because the filter is the bottleneck.
5. The evaporator gets colder than intended
Normally:
Warm cabin air → evaporator → cooled air
With poor airflow:
Less heat reaches the evaporator.
The evaporator temperature drops much lower.
The system may begin limiting compressor output to prevent evaporator freezing.
Now you have:
colder evaporator
less airflow
reduced total cooling
This is common behavior in air-conditioning systems.
6. Air outlet temperature can actually be colder
Here's the interesting part.
With the restrictive filter:
outlet air might measure 40°F
but only a small amount reaches the cabin
Without the filter:
outlet air may measure 46°F
but much more air flows
Which cools the cabin faster?
The second one.
It's like comparing:
a tiny trickle of ice water
a large stream of cool water
The larger stream transfers much more heat overall.
7. Why removing the filter suddenly made it "too cold"
Once you removed the restriction:
blower airflow increased dramatically
more air crossed the evaporator
cooling capacity returned
cabin temperature dropped much faster
The automatic controller was still requesting aggressive cooling because the cabin had been warm, so with full airflow restored the cabin overshot toward feeling very cold until the controller backed off.
8. Why manual mode can hide the problem
If you run:
Max A/C
High fan
Full cold
you may still get acceptable cooling because you're forcing the system to its limits.
Automatic mode tries to maintain a precise cabin temperature efficiently. It assumes each fan setting corresponds to a known airflow. A highly restrictive filter breaks that assumption, making the controller less effective even though the refrigeration system is still capable of producing cold air.
9. Why HEPA filters are uncommon in vehicles
True HEPA filters are rarely used in passenger vehicles because they require much higher fan pressure and larger filter area. Instead, automakers typically use:
Pleated particulate filters
Electrostatic media
Activated carbon layers (for odors and gases)
These offer good filtration while keeping airflow within the HVAC system's design limits. Some premium vehicles advertise "HEPA" filtration, but they usually pair it with specially designed, higher-capacity HVAC systems and larger filter assemblies.
In your case
The sequence you described is consistent with an airflow restriction caused by the replacement filter:
The software update was likely coincidental.
Replacing the cabin filter with a much more restrictive HEPA filter reduced blower airflow.
The automatic climate control algorithm continued to command cooling based on expected airflow, but the reduced air volume limited heat removal from the cabin.
Removing the filter restored airflow, allowing the system to transfer heat efficiently again, making the cabin cool quickly and even feel "too cold" until the controller adjusted.
From an engineering standpoint, the symptom wasn't that the automatic climate control "failed"; rather, its control strategy was operating outside its expected airflow envelope because the cabin filter imposed a much higher pressure drop than the system was designed for.
GarageMahal
JT
Data Wrangler
SOLVED!
Had the same issue with the same filter. Motorcraft FPP92 solved my problem although it doesnt filter quite as well (occasionally smells make it in) but the improved airflow is worth it to me.
