What to tap for extra USB outlets?
Shyatic
Lotus Emira, BMW X7
Hey all,
I have a 2025 Flash, and I'd like to add some extra USB ports for charging phones etc, but I'm not a fan of using the cigarette lighter since the location is so exposed. What are people using to draw power for things like USB ports in the car? I know I can use the mirror for a radar detector or dash camera, but outside of that I have other needs and don't want to have wires hanging around.
Appreciate any ideas!
B177y
Olympic Peninsula, WA
Hey all,
Don't you have two USB ports in the bottom right of the center console?
Shyatic
Lotus Emira, BMW X7
Bottom left, but the goal is to hide them entirely. I was going to mount USB ports underneath the dashboard somewhere.
B177y
Sorry, I need to define better... The center console under the armrest. Might be the "mobile work space" in your trim level...
Ford F-150 Lightning What to tap for extra USB outlets? 2026-08-0213.45.174123452225972603512
Ford F-150 Lightning What to tap for extra USB outlets? 2801
Ford F-150 Lightning What to tap for extra USB outlets? 2798
Shyatic
Lotus Emira, BMW X7
Ah, didn't even think to look there - will report back! Either way, not sure that they put out a lot of power so we'll see if that works.
Shyatic
Lotus Emira, BMW X7
Yep, they are there! Now I need to figure how to route power for them out of the console. Think I can drill a grommet into the side and that will be the easiest, but open to suggestions.
K6CCC
Glendora, Calif.
My first thought was "you already have six. How many do you need?"
Plus the wireless charging pad (if that exists in your year / trim).
B177y
What @jamelski said... Use the notch (top circle).
Ford F-150 Lightning What to tap for extra USB outlets? 2802
Shyatic
Lotus Emira, BMW X7
I actually found fuse number 10 which is the cigarette lighter and I'll add a fuse tap for that and a USB panel. Can hide that more easily and no need to have to worry about the wires anywhere.
DavidS
DAVID
Green Bay, WI
F150 Lightning Lariat
On my recent road trip, I just took along my Anker Prime charging hub and plugged it into one of the two cabin 120V ports. 200/250W of power in all the ports you could possibly use. You could easily just place one in the passenger side pockets of the center console. Mine just sat on the armrest for easy access.
A lot of fuses identified in different threads with plenty of power for dash cam's, find and use those. Also the console is pretty easy to get into, pull the top parts off and tap into the wires under the console, where those USB's inside are connected to.
