sotek2345
- First Name
- Tom
- Jun 7, 2021
- Upstate NY
- 2022 Lightning Lariat ER, 2021 Mach-e GT
- Occupation
- Engineering Manager
The weight difference between SR and ER is only 200 lbs. That is nothing for a truck. Yes the Lightning will be heavier than a regular F150, but it isn't far off a RAM or Silverado that is still using a steel body. Truck tires are made much stronger than car tires so this extra load shouldn't impact them at all.One thing to keep in mind is that the truck with standard battery will be ridiculously heavy, with ER, it would be worse. Many disadvantages including added stress on tires.
Any EV you buy now will look like a bad choice three years from now looking at how much better the new EVs are. The lower the price the lower the regret. Go for Pro.
That said, if a Pro works for you - go for it. Ford makes lots of different trims and options because we all want and need different things!
