ZeusDriver
- Dec 1, 2025
- East Coast, USA
- 2022 Lightning
The short version of what's below:
Has anyone here used a 120 VAC input (such as from a "power bank" inverter, or the 120 VAC outlets on a standard short range XLT) to operate a Generac 6854? Generac tech support was of no use. I have the unit wired up, and it will serve my needs, but the push button operation of the main switch does not work so far. Many "power banks" (battery/inverter units) output 120, but not 240, and this switch would be useful for connecting those to a home to feed essential services. Also, it would be useful to enable my Lightning to feed those services, which it could do for about a week or more.
The painfully long version:
I ordered the Generac 6854 via Amazon. According to the Amazon listing, this 30 A version operates on 120 VAC, whereas the 50 amp version operates on 240 VAC.
However, the owner's manual says it only operates with a 240 VAC input. (These switches are "manual" but the mechanical movement of the main switch itself can be accomplished via a pushbutton that causes a solenoid to operate, which yanks on the switch linkage.) The manual and other paperwork that comes with the switch does not provide a schematic -- just somewhat crude wiring diagrams that do not, for instance, show what happens inside any of the devices (which are mainly just switches). From tracing wires, I could see that the indicator lamps on the panel are 120 vac, but as the unit is wired, the solenoid that switches from one mode to the other runs on 240 VAC.
The solenoid that yanks on the main switch to change modes, has four leads, which I first thought were there for convenience (two for each end of the solenoid coil), but I suspect that the coil may be dual voltage, and getting it to work on 120 may be as simple as plugging in the right leads.
The Generac tech went on at some length about his plan to charge an electric vehicle with an onboard wind turbine. (I have met similar types who have suggested just turning on regen to charge as you drive... or just tow a trailer with one wheel connected to a generator... etc, etc. ... all perpetual motion schemes.) He also appeared to know nothing about the product itself, and thought that if I hooked it up to 120 VAC from my truck, that the truck would blow up. I'd hoped he could send me a real schematic, but he could not.
Instead of sending the unit back, I tested it, and everything works fine, provided I move the main switch by hand (they provide a little lever for that purpose).
The weather outside is frightening... so the panel is live, and I try not to do much work on live panels. But pulling a couple leads off the solenoid indicates that it is not wired as I had assumed, with there being 8.8 ohms (a coil with a lot of turns) between the orange leads (that I had assumed were joined at one end of the coil... given that there is no good way of telling them apart.) I can certainly get the solenoid working, possibly just by switching leads around, but I thought that someone here may have already done this, and you could save me some investigative work.
A long search produced a thread (at gentekpower.com) that indicated that several people had the issue of the buttons not working correctly. At least one of these people was trying to make the switch work with a 120 vac source. Another was using a Generac generator (which outputs 240 vac) but was having the same issue, and he'd found tech support useless, too. In that thread, however, there was a far better wiring diagram than my manual has... not a real schematic with each switch contact shown, but at least with the wires from device to device shown accurately.
