mr.Magoo
But thats the whole point - you're making that conclusion based on the presumption that higher current equals higher energy loss (i.e. voltage drop) in the the cables feeding your EVSE and from the EVSE to the truck.My only point is simply that higher current is not more energy efficient.
While this would be the correct conclusion IF, and only IF, all other parameters (including time) are constants.
The problem is - they're not.
Even if you look at it from a favorable (to your point of view) position, say we take a 80A 3AWG install and we run it at 40A instead, your voltage drop is now 1V vs. 2V so you "save" 120W. (in reality people would probably use 6AWG so your drop / losses are higher and your "savings" as a result are even lower).
But the truck is using about 200W to keep things alive during charging and now you're charging twice as long, so you're using 2.9kWh (12h x 200W + 40W) as "overhead" in the 40A scenario to charge your truck from 10% to 80%, but you'll use 2.2kWh (6h x 200W + 160W) in the 80A scenario.
So yes, your thermal losses are lower with lower charging current, but that doesn't make it more energy efficient since there's overhead to account for.
