12 volt battery bulging!
Ncasini
Nick
SouthWestern PA
2025 Lightning Flash
Check your 12 volt battery to see if it’s bulging. Mine is and I noticed a recent youtube video about replacing the 12 volt battery and it was also bulging. I’m concerned that this is a problem. Dealer seems unconcerned. What do you think?
I only looked and noticed the bulging after a notification about power saving after the truck wasn’t used for a week this winter.
Battery still checked ok.
Lpotter86
Lee
Durand, MI
23 ER
I preemptively replaced mine a couple months ago and my original (2023) was bugled on the sides.
Adventureboy
Ontario
Bulging is usually caused by freezing due to a combination of low SOC and cold temperatures. It damages structures inside the battery. Even if it tests ok, I'd replace it ASAP.
Eastbaylightning
Antz Tony
Walnut Creek, California
F150 Lightning Pro
I haven't checked mine yet (Original from Jan 2023).
Would you post the picture please?
Bulging could be from subjecting the battery to high currents resulting in excess heat during charging which the Lightning BMS seems to do according to some measurements made by owners.
The system allows the battery to get discharged without topping it off as well which can cause sulfate plating a different problem.
A charging current above 10,5A for a 35Ah AGM battery would normally not be recommended.
After you get your new battery, get a battery maintainer and use it regularly to keep the battery topped off to 100% as much as possible - I do it every day when the truck is not in use. My truck is 2 years old and the SOH according to my UNI-T battery tester is still 100%.
I have a 2012 Nissan Leaf with a 13.25 year old flooded battery with an SOH of 80 percent, still good, still does the job.
It is basic battery chemistry that lead-acid batteries will last a long time if kept at 100% as much as possible.
A $40 charger/maintainer like the NOCO Genius1 for example, is a lot less money and hassle of replacing a battery after the warranty has expired.
Just saying...
PS: no bulging here
Pod
2023 AMB Lightning XLT SR
What did you replace it with?
klossfam
Jeff
East Amherst, NY
2022 Lightning Lariat & 2022 Hyundai Ioniq 5 Ltd
I bought a new Motorcraft BAGM-H3 in Jan 2026 (with a 11/25 mfr date) from RockAuto. This replaced the original from May 2022.
By April it was bulging on the sides and by May I was getting the usual 12V not charging issues. Frunk issues, alarm randomly going off, etc. Tested as BAD CELL today and working on a warranty return.
I was just going to go all in on the Diehard AGM H3-XEV with a little more capacity. Long story short, I ordered one for pick up and Advance Auto calls and says ours has a 12/24 date so we can only sell it as 'used' for $59.99 with a 90 day warranty.
I took my tester, headed down to AA, tested fine for a shelved battery. Put it on my Viking Digital charger/repairer and then installed.
Only part of a day but seems good and no bulging. We'll see if I got a deal but worth the try for $60 on a Lightning with 84K miles.
21st Century Truck
Martin
Nice mileage Jeff! See You and Your Lightning on the open road!
