Platinum Peasant
West Sacramento
@Jesse-Infotainment I dropped my truck off and asked for the IPMA update again. The dealer and I got to talking and he told me that it’s the IPMB module, not IPMA that runs the all around cameras, and that IPMA is the one that operates the front camera for stuff like cruise control, lane assist, etc.
Im wondering what your thoughts are as I’ve never heard of the IPMB Module.
Jesse-Infotainment
Jesse
2024 F150 Lightning Platinum
This is not true. SO UNTRUE
The ipma handles all cameras
Platinum Peasant
West Sacramento
what does the IPMB do then?
I did forscan mods on my brothers 22’ superduty tremor (he has all the cameras at speed) and he has an IPMA and IPMB module show up. Never opened the IPMB one tho. My truck doesn’t even have IPMB show up.
Jesse-Infotainment
Jesse
I don’t know if I can even do this. Here you go. This is direct from ford wiring. The ipma handles all cameras all sensors all radar all cruise.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 9A97A9F4-66C3-4BF3-BE2B-625868F99AC4
Jesse-Infotainment
Jesse
What trim is the truck you’re referring to?
Jesse-Infotainment
Jesse
From what I read the B handles analog cameras. As far as I know the only camera that is analog in 21 is cargo cam and still it goes to the ipma. I’ll try and see if I can get specifics on it but I haven’t encountered it. If someone else knows maybe they can chime in. I don’t know 100%. Even the STx like mine had a digital rear view camera. It was analog from the ipma but I was able to convert it to digital. The ipma is the same for rear view cam only trucks
Jesse-Infotainment
Jesse
I also have my cams at speed. I have a job one truck and ipma.
Caneman88
Ron
San Antonio TX
2021 Powerboost F150 Platinum ,2009 370Z
Pella Windows and Doors
Here's some things to try:
IPMA 706-02-02 xxxB CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-02 6xxx xxxx xx--
APIM 7D0-01-04 xxxx EDxx xx--
Do an APIM reset under the wrench icon after the APIM changes.
I did this and got hitch cam at speed but lost bed cam not selectable any more
any help would be great
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? Screenshot (231)
Jesse-Infotainment
Jesse
Looks like the IPMB may have to do with Trailer reverse guidance..
I have mine all working. The only problem is you only get the hitch cam and the cargo cam in motion. The others are not selectable. You can also only switch through the cameras in motion with the camera hard button. If you initiate the cam in motion.. come to a stop and then use the soft button to select the front camera I believe then it will stay on.
I used the 21.5 trucks as a guide for the cam in motion. My entire set up is after the fact anyway.. I didn’t have 360 or 12” from the factory I added it all. Along with the cargo cam.
Shyrax
Jason
AL
‘21 F150 Limited
IT Management
Anyone found a way to enable walk away auto lock? After 5 years of just walking away, habits are hard to break. I remember an hour or 2 later that I did not lock it.
JIMFOUNTAIN
2021 F150 SCREW PB 6.5' 701A
Same issue with mine.
I has same issue after Lincoln mode, after restore to original values puddle light works
Ok.. Lincoln fold with tow mirrors means no puddle lights. Got it.
Anyone have Lincoln fold with the stock mirrors? Do puddle lights work?
Snippy
F150
I hate to be redundant here, but anyone have the correct values for the cameras at speed for a XLT 302A, FX4 ?
These values didn't seem to work for me unfortunately:
"7D0-01-04 = xxxx-FCxx-xxxx Originally = 01 in those spaces
706-02-02 = xxxF-CExx-xxxx Originally = 0, 4, C
Things I have changed, but not sure if they affect it at all (yet):
706-01-01 = xxxx-Axxx-xExx Originally = 8 and C
7D0-01-02 = Axxx-xxxx-xxxx Originally = 2"
Platinum Peasant
West Sacramento
My truck is platinum, bro’s truck is a lariat.
Platinum Peasant
West Sacramento
So with the IPMA update and these changes, you’ll get the cargo and hitch cam correct?That’s why I asked them for the IPMA update.
Jesse-Infotainment
Jesse
Yes. The update and there are as built data changes in the APIM required for the cams to work in motion. The cargo cam will NOT be full screen though land will not be available in the side stack. The newer trucks have those capability. Even with the update the early truck do not
